Gtir Motorsport club » Tech room » Help and Advice » Oil pressure
Oil pressure
1 Oil pressure on 13th April 2014, 10:22 am
Trtrucker
Hi not long had the car but having trouble with the turbo leaking oil out replaced turbo with a used spare i have of my scrap pulsar went to race retro used it on the demo rally stage and now thats done the same . Just wondering if i have to much oil pressure and how if possible to reduce it
2 Re: Oil pressure on 13th April 2014, 10:51 am
What's oil pressure reading at hot idle?
And what turbo are you running on her?
3 Re: Oil pressure on 13th April 2014, 11:58 am
gtirx2
Blow by can also cause this as my friend has just had the same on his evo.
Started with leaking around the core of the turbo then started blowing blue smoke now and then and slowly getting worse.
Car still ran well with no signs of any other problems but infact had broken ring llands on 2pistons.
I think the gtir's breather setp is slightly better/bigger than the evos so may not be as prone to showing signs this way but its still always a possibilty,i would compression test it.
4 Oil pressure on 13th April 2014, 3:40 pm
Trtrucker
Hi thanks for your reply its running a standard garret t25 turbo and the oil gauge showing just over 4k cm at tick over hot and when revved goes up towards 8 on the scale , as a old timer i no idea what that is (still work in ft and ins) thanks again
5 Re: Oil pressure on 13th April 2014, 3:53 pm
Hardy172cup
I'm no expert but I have studied oil pressure readings in sr20's extensively because I had oil pressure probs of my own.
Your readings sound a little high to me from what I have read online
6 Re: Oil pressure on 13th April 2014, 4:10 pm
Hardy172cup
These are my oil pressure readings
6 on cold start up and gradually creeps down as the engine wrms up.
Just over 2 hot idle
Just over 4 cruising
And up to as high as 6 when giving it some boot.
7 Re: Oil pressure on 13th April 2014, 6:15 pm
Yeah 4 is a bit high at hot idle especially rising to 8 on the move
You may have a faulty oil pressure sensor so could be worth trying another to see if it reads the same or drops
If still high I would say your oil pressure relief valve in the pump may be sticking and not releasing the pressure which could give you major probs with pressure seals in the tubby.
Could also be a kinked or blocked return over pressurising turbo or as said above if you have a cracked ring land you'll end up with excess crankcase pressure which also won't help your cause.
Or could just be the replacement turbo you fitted was on its last legs
8 Re: Oil pressure on 13th April 2014, 6:44 pm
Trtrucker
Hi thanks for that this is what i was worried about just fitted a refurb. turbo well will go from there?
9 Re: Oil pressure on 13th April 2014, 6:59 pm
Just because it's been referbed don't rule it out as being faulty, I've had rebuilds in the past that have only lasted 2 days so it may still be faulty but check that oil pressure ect as it could be blowing the seals
10 Re: Oil pressure on 13th April 2014, 7:15 pm
My mate blew a seal once. Never worked in that zoo ever again
11 Re: Oil pressure on 13th April 2014, 7:26 pm
@Bones wrote:My mate blew a seal once. Never worked in that zoo ever again
Quality lol! lol! lol!
12 Re: Oil pressure on 13th April 2014, 7:58 pm
That's disturbing  Shocked Laughing
13 Re: Oil pressure on 13th April 2014, 9:14 pm
Trust darren to bring tbe tone down.. Laughing
14 Re: Oil pressure on 13th April 2014, 11:28 pm
my mate has just had his turbo rebuilt by AET Turbos, Fitted it, primed it took it for a steady drive & it was still smoking exsevily, he cleaned intercooler & boost pipes out & still the same... I took the inlet pipe off the turbo for him & you could move the shaft in & out about half an inch  Rolling Eyes  & that was after 5 miles of steady driving after rebuild! Lucky its under warrenty but still could have the same issue again!
15 Re: Oil pressure on 14th April 2014, 10:00 am
thing is when you go back to the turbo builders they always always blame the prob on the car  Evil or Very Mad  even though you know damned well theres nothing wrong with it
I will never have a turbo rebuilt again after two bad experiences with Essex turbos, not all are bad but they all come out with the same crap when its clearly a bad build which is very annoying
