Gtir Motorsport club » Tech room » Help and Advice » oil pump change
oil pump change
1 oil pump change on 15th April 2014, 9:03 pm
Trtrucker
Hi need help how to change oil pump and if engine has to come out ,if so whats the best way to remove engine , can it come out without removing the transmission ,thanks
2 Re: oil pump change on 15th April 2014, 9:44 pm
Have you tried a different oil pressure sensor first before such drastic measures?
If so and that didn't work you can do the pump with engine in situ but it's not an easy job to do
If I get a chance tomorrow il do a write up how to do it for you or give me a bell and il explain over phone
3 Re: oil pump change on 17th April 2014, 2:41 pm
Trtrucker
Hi what about getting at the relief valve is that possible
4 Re: oil pump change on 17th April 2014, 3:01 pm
no not without unbolting the cover as you cant get a spanner in to the cap bolt unfortunately
5 Re: oil pump change on 18th April 2014, 11:33 am
Trtrucker
I forgot to say this a track /rally car strip out roll cage coil over suspension front intercooler and oil cooler
