Gtir Motorsport club » Tech room » Help and Advice » The 1 bar loop
The 1 bar loop
1 The 1 bar loop on 18th April 2014, 10:26 am
Hardy172cup
Can someone explain in detail how to do the 1 bar loop?
Last time I tried it my car just boosted like crazy. I think it may of been down to the t peice I used but I just want to make sure I'm doing it right?
2 Re: The 1 bar loop on 18th April 2014, 11:08 am
Theres a diagram in the useful diagrams wich shows you how to do it but you will need the restrictor pipe otherwise you wont get 1bar bill....
3 Re: The 1 bar loop on 18th April 2014, 11:09 am
Hardy172cup
I've got the restrictor pipe mate, I'll take a look at the diagram now
4 Re: The 1 bar loop on 18th April 2014, 11:14 am
Hardy172cup
I like how it's called "the dodgey 14 psi trick" Laughing
I might just stick with the unstable bleed valve. I'm scared to try the 1 bar loop mod again because my turbo about shit itself last time! Lol
5 Re: The 1 bar loop on 18th April 2014, 11:22 am
It should be safe to run a bar mate .... think i have another diagram somewhere ... il dig it out for you .
6 Re: The 1 bar loop on 18th April 2014, 11:27 am
7 Re: The 1 bar loop on 18th April 2014, 11:46 am
Hardy172cup
The thing is when I did it last time it hit about 1.4 bar before I backed off. I may of crushed the t peice putting the pipes on because it twisted when I pulled the pipes off. I'm just afraid to do it again incase it wasn't the t peice at fault
8 Re: The 1 bar loop on 18th April 2014, 11:50 am
basically as above it just bleeds off into the induction pipe.
I cant really understand why they call it a 1 bar loop because if you disconnect the multiplug from stock boost control solenoid you don't even have to loop it and it will still hit bang on 1 bar with restrictor pipe just by bleeding it back into intake
9 Re: The 1 bar loop on 18th April 2014, 11:51 am
I would think it was more an likely be the tpiece as its the same efect as the restrictor ...
10 Re: The 1 bar loop on 18th April 2014, 11:52 am
Hardy172cup
I'll try it again and see what happens
11 Re: The 1 bar loop on 18th April 2014, 12:21 pm
Hardy172cup
I can't explain why but I'm getting well over 1 bar with "the 1 bar mod"  confused
I'm seeing 1.2 - 1.3 bar and I dare not keep my foot in any longer to see what it's boosting to.
God knows why it's doing that?
12 Re: The 1 bar loop on 18th April 2014, 12:34 pm
You've not caught a hose have you and its running unlimited?
13 Re: The 1 bar loop on 18th April 2014, 12:39 pm
Hardy172cup
No mate I'm sure I haven't, I just put the t-peice were the MBC was and T'd it to the intake pipe as per the diagram. I don't understand why it's doing that and I don't want to find out if theres a limit to the boost when it's set up that way because as soon as I see it go over a bar I poo my pants lol
