Gtir Motorsport club » Tech room » Help and Advice » Fault code check not working???
View previous topic View next topic Go down  Message [Page 3 of 3]
51 Re: Fault code check not working??? on 24th April 2014, 5:22 pm
Hardy172cup
I think Ive found out why the fault code check it's working!
The fuse for "engine control" has blown. I've got a feeling it will blow again if I replace it because it had a 15 amp fuse in it instead of a 10 amp fuse so looks like somebody has put a higher rating fuse in to try to stop it blowing fuses.
I noticed half the fuses in the car are the wrong rating, there were a few 15 amp fuses where there should be 10 amp fuses Rolling Eyes
52 Re: Fault code check not working??? on 24th April 2014, 5:23 pm
Hardy172cup
I'll put a 10 amp in and see what happens and I will report back
53 Re: Fault code check not working??? on 24th April 2014, 5:35 pm
Hardy172cup
I've sorted that out, it's doing the fault code check now Smile unfortunately though when I did it, the piece of metal I sussed to bridge the 2 pins snagged when I pulled it out and I accidentally cleared the codes before I got chance to read them! Rolling Eyes
I'll have to run it for a bit and then fault code check it again lol
54 Re: Fault code check not working??? on 24th April 2014, 8:11 pm
I put a rocker  switch into mine with two wires bridging the pins that way i only have to flick the switch and bammmm shes fault finding ....
55 Re: Fault code check not working??? on 24th April 2014, 8:17 pm
I find a pair of tweezers does the trick nicely but a toggle switch is a brilliant idea Leighton
                                GTI-R-US.CO.UK
                                            'In association with'
                                          'Services provided'
56 Re: Fault code check not working??? on 24th April 2014, 8:22 pm
Hardy172cup
Yeah I'm liking the title switch idea, makes things nice and easy. Darren's given me a little peice of metal to use on mine that's the perfect size so I'll just keep that in my ashtray from now on  thumbsup
57 Re: Fault code check not working??? on 24th April 2014, 8:51 pm
I used to keep a paper clip in my ashtray but since i carved it up to fit my boost controller i thought i best do something else .... hence the switch  Wink
View previous topic View next topic Back to top  Message [Page 3 of 3]
