Gtir Motorsport club » Tech room » Help and Advice » How to check and adjust TPS?
1 How to check and adjust TPS? on 22nd April 2014, 9:23 pm
Hardy172cup
How do you check the throttle position sensor? And if it's not within spec how do you adjust it?
I'm wanting to check it to see if it's within spec because its something I haven't checked yet and I'm thinking maybe it could be cause of my little misfire at partial throttle?
2 Re: How to check and adjust TPS? on 22nd April 2014, 9:25 pm
Time to get your multi meter out again buddy ..
And 2 screws to adjust it
3 Re: How to check and adjust TPS? on 22nd April 2014, 9:25 pm
At this rate we'll soon be able to build one of these footers blind folded bill
4 Re: How to check and adjust TPS? on 22nd April 2014, 9:28 pm
Hardy172cup
I know I've had to bloody check and chane everything and still no joy with this little misfire, im determined to figure out what it is!
What do I need to connect my multimeter up to mate and what am I checking for?
5 Re: How to check and adjust TPS? on 22nd April 2014, 9:32 pm
Think you check resistance or summit .. not sure what numbers are etc .. remove the plug and check pins etc .. Someone else will know
You put new plugs in it yet
6 Re: How to check and adjust TPS? on 22nd April 2014, 9:36 pm
Hardy172cup
Yes mate, running spot on at 0.7mm gap now, other than the misfire at partial throttle which has always been there. It was idling rough with the old plugs at 0.7 but it idles fine with the new ones Smile
7 Re: How to check and adjust TPS? on 22nd April 2014, 10:07 pm
He means the plug on the tps bill. Not spark pug, huuuu some mechanic lol
8 Re: How to check and adjust TPS? on 22nd April 2014, 10:08 pm
Other than that his reply was very informative lol
9 Re: How to check and adjust TPS? on 22nd April 2014, 10:27 pm
Hardy172cup
He said "you put new plugs in it yet" actually Razz so I'm assuming he means spark plugs Razz
