Gtir Motorsport club » Tech room » Help and Advice » Speedo cable?? Delimiter questions
1 Speedo cable?? Delimiter questions on 24th April 2014, 11:36 am
Turbazz
my speedos stopped working.. Because I have been messing around underneath my car reckon I have knlocked the cable
I could only find this hanging...
Is this it why does it look broken?
Where does it go?
Something missing?
While I am sorting this issue out. How do I convert to mph
2 Re: Speedo cable?? Delimiter questions on 24th April 2014, 11:36 am
Turbazz
3 Re: Speedo cable?? Delimiter questions on 24th April 2014, 11:37 am
Turbazz
4 Re: Speedo cable?? Delimiter questions on 24th April 2014, 11:38 am
Turbazz
5 Re: Speedo cable?? Delimiter questions on 24th April 2014, 11:39 am
Turbazz
is like someone has superglued it
6 Re: Speedo cable?? Delimiter questions on 24th April 2014, 11:43 am
weve got good ones in stock if needed
that looks fooked
7 Re: Speedo cable?? Delimiter questions on 24th April 2014, 11:45 am
Turbazz
Something missing Bob? Found a hole on the gearbox cant connect up?
8 Re: Speedo cable?? Delimiter questions on 24th April 2014, 11:59 am
Is the missing bit still in the Gearbox??
Should have a plastic gear wheel on the end....
9 Re: Speedo cable?? Delimiter questions on 24th April 2014, 12:10 pm
Turbazz
No idea does anybody have a picture. What this thing looks like complete
10 Re: Speedo cable?? Delimiter questions on 24th April 2014, 12:14 pm
Turbazz
Is a matter of just getting it on? It was working fine before
11 Re: Speedo cable?? Delimiter questions on 24th April 2014, 12:29 pm
It's similar to this
12 Re: Speedo cable?? Delimiter questions on 24th April 2014, 12:32 pm
It's located infront of the 'bastard' bolts on the gearbox.
If you put your hand down under the plenum where the gearbox meets the transferbox it's there.
It actually bolts into the transferbox.
13 Re: Speedo cable?? Delimiter questions on 24th April 2014, 12:59 pm
Turbazz
Why does mine not look like that.
14 Re: Speedo cable?? Delimiter questions on 24th April 2014, 1:02 pm
Turbazz
How many bastard bolts does this car have lol. So cramped. I reckon I hit it when trying to remove the Y bracket
15 Re: Speedo cable?? Delimiter questions on 24th April 2014, 1:15 pm
The one I showed you isn't a Gtir one but it's an sr20 one so is very close.
Yours is dark grey from all the shit over the years lol
If you removed all of it, it will look very much like the one I posted up Wink
16 Re: Speedo cable?? Delimiter questions on 24th April 2014, 3:30 pm
basically what you've done is pull the outer casing and connections off
your gonna have fun getting the rest of it out as some of them are in there very tight even by grabbing hold of the top bit with the 10mm securing nut out they can be a real bitch
good luck
