Gtir Motorsport club » Tech room » Ecu related section » FAO Gaz GTiR
FAO Gaz GTiR
1FAO Gaz GTiR Empty FAO Gaz GTiR on 26th April 2014, 7:30 pm
Spark plug spike
Spark plug spike
Gaz, I have just been reading back through some of the ECU threads and noticed that you said on one of them that you sent your ECU to Ed at Fusion to get the Nistune chip installed?
If that's the case then your TPS and base timing being out maybe the reason for you running rich as it is not set up correctly?
Try and set your TPS to between 0.45 and 0.55 volts and base timing to 20 degrees and see if that cures it?
2FAO Gaz GTiR Empty Re: FAO Gaz GTiR on 27th April 2014, 2:12 am
I gave Ed a ring yesterday & he said that the TPS is ok @ 0.10 If it was over 0.50 then id have an issue, anything below 0.50 is ok...
I meantioned that when we put the TPS to 0.50 that it put the timing to 30 degrees!
He said don't touch it & leave it as it is because if I adjust the timing once TPS is @ 0.50 then it will mess with the map... Which is what Bob said so was a good job we left it @ 0.10 Wink
It is 5 years since it was mapped so I think its just overdue a check over & remap!
3FAO Gaz GTiR Empty Re: FAO Gaz GTiR on 27th April 2014, 7:39 am
yep I would when the times right reset the tps and base timing and get the map tweaked to that.
notice spike thinks of you gaz but ignors this northern boy re making me a lead and I pay him which I would prefer or worst case a pm telling me what and how to do it ball age   hijacked
4FAO Gaz GTiR Empty Re: FAO Gaz GTiR on 27th April 2014, 9:18 am
Spark plug spike
Spark plug spike
Ok no worries Gaz I'm sure it will be sorted with a tweak of the map.
Johnny I could make a lead up for you, but being a sparky I'm sure you can knock one up  thumbsup
Here's the link that I used, just don't buy the lead from Maplins as they are mega expensive. I also grounded it down by the fuse box.
http://www.evoxforums.com/forums/showthread.php?t=21747
5FAO Gaz GTiR Empty Re: FAO Gaz GTiR on 27th April 2014, 12:38 pm
Haha sounds like favourtism that Johnny  Laughing
Cheers for your help tho spike, appreciated Smile
6FAO Gaz GTiR Empty Re: FAO Gaz GTiR on 27th April 2014, 5:03 pm
I maybe I will tell him its for you lol or say my address is ...... southern fairyland ha
No its all sorted now
very interested in what he learnt me on RR day and will be asking for more info demos next time I see him
great guy and excerlant knowledge from him on a subject that I am very interested in
7FAO Gaz GTiR Empty Re: FAO Gaz GTiR on 27th April 2014, 6:18 pm
Spark plug spike
Spark plug spike
No problem guys, Johnny I will even make the cable FOC for all your help on the RR day mate so you are definitely the favourite one soz Gaz  moonie
8FAO Gaz GTiR Empty Re: FAO Gaz GTiR on 9th May 2014, 5:18 pm
Spark plug spike
Spark plug spike
Cable all made up and posted today Johnny  Very Happy
I have put a bullet connector on the wire to connect to the blue wire on the AFR loom, the other one is the earth.
9FAO Gaz GTiR Empty Re: FAO Gaz GTiR on 9th May 2014, 9:37 pm
top man you goin to spint day ? I phones just totally crashed so god knows what is saved to I cloud or whatever shit it is will try apple shop tomorrow if your going will square you up there
10FAO Gaz GTiR Empty Re: FAO Gaz GTiR on 9th May 2014, 9:55 pm
Spark plug spike
Spark plug spike
@johnny gtir wrote:top man you goin to spint day ? I phones just totally crashed so god knows what is saved to I cloud or whatever shit it is will try apple shop tomorrow if your going will square you up there
I'm off to Portugal for a week so won't make it to the sprint day, you don't owe me for it as I said I would do it for you after you helped me on the RR day mate.
11FAO Gaz GTiR Empty Re: FAO Gaz GTiR on 9th May 2014, 10:40 pm
thought if I paid you would of took me to Portugal for a holiday  Very Happy
thank you very much mate people like yourself make owning a pulsar or 3 worth while
enjoy your hols and if I don't see you before see you at the club event
12FAO Gaz GTiR Empty Re: FAO Gaz GTiR on 20th May 2014, 6:40 pm
arrived thanks a lot for all your time and effort
