Gtir Motorsport club » Tech room » Help and Advice » Compression test
Compression test
1 Compression test on 28th April 2014, 4:11 pm
Turbazz
How do I do one of these? I Have a top Mount intercooler is it okay to leave it off?
2 Re: Compression test on 28th April 2014, 4:27 pm
grim_d
Get engine warmed up. Remove all spark plugs and stop fuel getting in.. pull pump fuse or remove injector plugs. Screw compression tester into spark plug hole and have someone crank it over at wide open throttle. Should stabilise at around 4/5 cranks.
Record reading and repeat for other 3 cylinders, it's ok to leave intercooler off.
You are looking for between 130 - 170psi roughly but gauges vary, the most important thing is reasonable consistency between cylinders. I did a compression test yesterday and had around 150psi on all 4 with a cheap sealey gauge which I think reads a touch under
Under 130psi and put a teaspoon of oil down the plug hole and repeat test, if it improves compression it indicates a problem..
3 Re: Compression test on 28th April 2014, 4:50 pm
Turbazz
Do I need to take all 4 plugs out or leave three in each time?
DoI need to disconnect anything from the distributor?
4 Re: Compression test on 28th April 2014, 4:52 pm
Take all 4 plugs out & leave dizzy as leads are not connected once plugs are out
5 Re: Compression test on 28th April 2014, 5:18 pm
Hardy172cup
Best thing to do is disconnect the little silver box in the top right of the engine bay next to the top of the strut. That's the resistor pack for the injectors so with that disconnected no fuel will be injected Wink
6 Re: Compression test on 28th April 2014, 6:58 pm
Yep as bill says the resistor pack is probably the quickest way to disable the injectors its a multi plug so it just unclips ....
7 Re: Compression test on 28th April 2014, 7:09 pm
grim_d
That would definitely be the easiest way to disable the injectors, didn't think of that.
8 Re: Compression test on 28th April 2014, 8:34 pm
Turbazz
177 Psi on all 4.
I had oil on my plugs on the thread though not lots just a bit..
The actual point was dry seemed fine.
9 Re: Compression test on 28th April 2014, 9:27 pm
The oils probably come from the o rings leaking under the rocker cover and filling the plug wells with oil in which case soon as you removed the plugs the oil would have dropped into cylinders and would give you a false reading
But even so if they were all the same that's a good reading
10 Re: Compression test on 28th April 2014, 9:43 pm
Exactly what i said lol ....
11 Re: Compression test on 28th April 2014, 10:46 pm
Turbazz
Is there a guide how to replace these? And what's the part number on the seals
12 Re: Compression test on 28th April 2014, 11:21 pm
grim_d
Easy to replace, pop the rocker cover off, pull the old gaskets out the cover, little smear of oil on the new gaskets and push them.
Part number not sure of - perhaps 13271-65F00 but that is stated as for s14.
Full gasket kits are available though - http://www.ebay.co.uk/itm/Nissan-Pulsar-Sunny-GTiR-Complete-Rocker-Cover-Gasket-Kit-/280874657703?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item41656f27a7
Part number for gtir rocker gasket is 13270-53J05 though I don't know if it includes the plug well gaskets.
13 Re: Compression test on 30th April 2014, 12:25 pm
http://www.importcarparts.co.uk/parts_info.asp?id=7916&cat=87&sub=119&sec=1184&var=0&dc=&gen=&searchKey=
14 Re: Compression test on 30th April 2014, 12:26 pm
Above link .... includes all you need .... plus £5.00 cheaper...
15 Re: Compression test on 30th April 2014, 4:19 pm
Turbazz
Cheers Leighton!
