Gtir Motorsport club » General Discusion » Gtir related Discussion » Linkage bushes
Linkage bushes
26 Re: Linkage bushes on 7th December 2014, 8:03 pm
I will see if i can find a pic of them for you
27 Re: Linkage bushes on 7th December 2014, 10:34 pm
Gaz, have a look at your centring spring (item 10) on that picture. my gearstick was well lose as gear stick didn't centre to the 3rd/4th gate and made shifting from 2nd to 3rd a pain as it would hit beetween 1st/3rd. Found my spring had stretched after I had fitted the poly bush your after and it had made little difference. spring is £8 from nissan
28 Re: Linkage bushes on 7th December 2014, 10:38 pm
Do you have the part number ?
29 Re: Linkage bushes on 7th December 2014, 10:46 pm
Spring-return, lever, 3457350J00
30 Re: Linkage bushes on 8th December 2014, 1:55 am
Cheers toaster, ill get 1 of them aswell Smile
31 Re: Linkage bushes on 17th January 2015, 9:37 am
Spark plug spike
Spark plug spike
Gaz, back on sale on ebay now, I have just bought a set.
http://www.ebay.co.uk/itm/SHIFT-BUSHING-Nissan-Pulsar-Sunny-GTiR-4x4-n14-n15-b13-Almera-Primera-/131403799955?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e9846dd93
32 Re: Linkage bushes on 17th January 2015, 12:00 pm
Top tip! Look on that sellers other items, he has same bushes listed on eBay oz site. If you buy them there you'll get them a few quid cheaper and save on postage! Make the exchange rate work for you, that's what I did!
33 Re: Linkage bushes on 18th January 2015, 3:57 am
^ Too right that bush is $7 or less direct from USA :-O
For one bush the eBay price is awful. I though the original eBay listing came with solid mount bracket too ! .
34 Re: Linkage bushes on 18th January 2015, 5:55 pm
Cheers Spike ill get a set orderd
35 Re: Linkage bushes on 20th November 2017, 8:01 pm
venom42
venom42
Sorry to revive a dead post, but I just ran across this. I can easily source the energy suspension bushings (part 7.1103G). I have also seen a billet "shift stabilizer" (there was a facebook post in a group today). Based on how they look, I assume these are for different issues? Should I replace both, AND the spring that was mentioned above? There just seems to be some looseness to the shifter, and I sometimes end up having to "hunt" to get it into gear.
Sorry if these are noob questions, but I just got my car and am working through the initial issues to get it up to par.
36 Re: Linkage bushes on 20th November 2017, 8:14 pm
you could get spring and bush as cheap and when fit those review shift stabilizer and if looks a problem replace it or mod it to solid or urathane bush.
37 Re: Linkage bushes on 22nd November 2017, 12:41 pm
SonaGTIR
im looking for the full bush kit to sort out my sloppy gear stick.
38 Re: Linkage bushes on 1st December 2017, 5:02 pm
venom42
venom42
@SonaGTIR wrote:im looking for the full bush kit to sort out my sloppy gear stick.
I found the bushing kit for $9.46 on Amazon with free shipping. Search for part number 7.1103G. There was a guy in the facebook group selling the solid mount as well. It is significantly more expensive though.
39 Re: Linkage bushes on 2nd December 2017, 11:58 am
Ryaneg6freak
Ryaneg6freak
The solid mount is one of the best upgrades you can do. Gspec performance has them cheaper than the guy in the facebook group, not to mention they're in the USA, not Australia.  The Gspec one however is made for a B13, and such you have to drill the center hole out a bit to get the GTi-R weight bolt through (it's a bigger diameter)
https://www.gspec.com/p-7375-rear-shifter-stabilizing-bracket.aspx
40 Re: Linkage bushes on 5th December 2017, 3:19 pm
SonaGTIR
I cannot find this anywhere is there a link to this you could post?
41 Re: Linkage bushes on 5th December 2017, 3:22 pm
venom42
venom42
Doing this from my phone. See if this one works: Energy Suspension 7.1103G Shifter Bushing Kit for Nissan https://www.amazon.com/dp/B000CN9AWE/ref=cm_sw_r_cp_apa_yMRjAbKXT334J
42 Re: Linkage bushes on 5th December 2017, 3:30 pm
SonaGTIR
nice one mukka
