Gtir Motorsport club » Tech room » Help and Advice » Random cutting out or dying
1 Random cutting out or dying on 13th May 2014, 8:13 pm
Darrooon
Car keeps dying on me and I don't know why, whether I'm driving hard or just taking it easy and it's really starting to piss me off now. I'll be driving along and next minute the engine starts dying on me no power at all drop a gear and still nothing pull over at a safe point and soon as I put the clutch in the car stalls and won't restart till about 10-15 minutes later then she dies again 5 mins later driving or just idling.
Any my help would be appreciated
2 Re: Random cutting out or dying on 13th May 2014, 8:18 pm
Fuel pump is my guess. . Over heating and seizing up
3 Re: Random cutting out or dying on 13th May 2014, 8:20 pm
Welcome to the forum, sounds like it could also be a coil pack failing?
4 Re: Random cutting out or dying on 13th May 2014, 8:23 pm
Darrooon
Cheers, will check over fuel pump on the weekend, coil pack ?
5 Re: Random cutting out or dying on 13th May 2014, 8:29 pm
When you say dying .... is there no power when it starts doing it mate ..... like going into safe mode ?
6 Re: Random cutting out or dying on 13th May 2014, 8:30 pm
You can ohm test the coil to check it ..... there is a diagram in the useful diagram section under my name ...
7 Re: Random cutting out or dying on 13th May 2014, 8:39 pm
Darrooon
Yeah pretty much like everything is slowly shutting down, had the rac man out and he said the spark looked a little delayed but not much and put it down to CAS
8 Re: Random cutting out or dying on 13th May 2014, 8:48 pm
It could be all the time the clutch is driving the engine its keeping it ticking over .... what mods etc do you have .... is it standard ecu ?
9 Re: Random cutting out or dying on 13th May 2014, 9:05 pm
Darrooon
Fmic, Ali rad, rc 750cc, 255 pump, turbo back mongoose, tubular mani, gt3071r, metal head gasket, apex power FC + hand commander recently had new plugs and leads, starter motor, alternator
10 Re: Random cutting out or dying on 13th May 2014, 9:16 pm
Ive just had the same problem night before last, But min wouldn't restart... It was getting no fuel so took fuel pump out & put it in a bucket of fuel & directly wired to battery, it was priming & turning over but not pumping any fuel threw... So maybe worth checking
11 Re: Random cutting out or dying on 13th May 2014, 9:17 pm
As said on phone the other day
Check the fuel pump and the filter sock as I suspect that may be blocking the fuel from entering the bump when coming on boost and you requiring more fuel so pumps cutting, check that first
Could also be a fault with the Clifford control box but I would try swapping the easy bits first then see how you go
Btw welcome to the forum   Smile
12 Re: Random cutting out or dying on 13th May 2014, 9:25 pm
Darrooon
Will defo check fuel pump on the weekend and maybe try disconnect the Clifford if have time, cheers bob
13 Re: Random cutting out or dying on 13th May 2014, 9:29 pm
Im wondering if my fuel pump has been dodgy for a while & was pushing to much fuel pressure threw & that's why I was running rich? & now its finaly given up. Guess ill only find out when I fit a new 1
14 Re: Random cutting out or dying on 13th May 2014, 9:32 pm
There is a how too .... with regards to fuel pump removel and fitting .... its a pretty easy job ....
15 Re: Random cutting out or dying on 13th May 2014, 9:42 pm
Darrooon
Probably a stupid question my battery is in the boot should I disconnect it when checking the pump ?
16 Re: Random cutting out or dying on 13th May 2014, 9:47 pm
I would just to be safe mate yeh
17 Re: Random cutting out or dying on 13th May 2014, 10:08 pm
I would ..... although you have to unplug the fuel pump and sender think abs sensor plug before you undo the tank anyway .... hopefully you havent got a full tank of fuel ....
18 Re: Random cutting out or dying on 13th May 2014, 10:28 pm
Darrooon
Just under half lol
19 Re: Random cutting out or dying on 13th May 2014, 10:32 pm
He's not removing the tank Leighton just the fuel pump from the tank
20 Re: Random cutting out or dying on 13th May 2014, 10:47 pm
I meant undoing the tank as in the top plastic ring and centre piece with the pipes on ...
21 Re: Random cutting out or dying on 13th May 2014, 10:48 pm
Reason i said about the fuel is sticking your hand in there ....
22 Re: Random cutting out or dying on 13th May 2014, 11:04 pm
Darrooon
Gloves it is then
23 Re: Random cutting out or dying on 13th May 2014, 11:10 pm
You wont need gloves ... its suprisingly cold ... did you put your previous pump in ?
24 Re: Random cutting out or dying on 14th May 2014, 4:44 pm
Darrooon
No was already in
25 Re: Random cutting out or dying on 30th May 2014, 4:40 pm
Darrooon
Finally sourced the problem and it was the maf sensor replaced it runs sweet as a nut  cheers
