Gtir Motorsport club » Tech room » Help and Advice » O2 sensor
O2 sensor
1 O2 sensor on 24th May 2014, 12:21 am
Turbazz
How long does it take the sensor to warm up to give me a reading on consult...If the sensor was faulty should it produce a error or fault code?
Lastly how much does it cost to replace theses Smile
2 Re: O2 sensor on 24th May 2014, 7:20 am
around 100 quid from Nissan I think I paid for mine not long ago . I heard that 90% of cars ie pulsars that get mapped they map around or without them as ther not working anyway
3 Re: O2 sensor on 24th May 2014, 11:02 am
Turbazz
Do they need warming up for taking the reading?
Is there not a cheaper alternative other than Nissan....
4 Re: O2 sensor on 24th May 2014, 11:16 am
Gl3nnGTIR
Thats right jhonny, i dont use any o2/lamba sensor on mine
5 Re: O2 sensor on 24th May 2014, 12:27 pm
@Gl3nnGTIR wrote:Thats right jhonny, i dont use any o2/lamba sensor on mine
Ill second that. Me either, was mapped round it as wasn't working
6 Re: O2 sensor on 24th May 2014, 4:25 pm
They should give a reading on all scales from cold to warm or wot .... but when the car is warm on idle -2000rpm is where you take the reading from what i understand this is the ideal/optimun temp for acurate reading ...
7 Re: O2 sensor on 24th May 2014, 5:38 pm
Turbazz
Yeah mine is dead! I need a replacement! from Australia £50...
8 Re: O2 sensor on 24th May 2014, 10:20 pm
Make sure you get the right one then .... you want the skinny type o2 sensor ....
9 Re: O2 sensor on 25th May 2014, 8:35 am
Nomad your slipping your posts usually have a link in them
10 Re: O2 sensor on 25th May 2014, 10:28 am
Lol i didnt link one as thought he had already bought it .... Laughing
11 Re: O2 sensor on 25th May 2014, 10:45 am
The pulsar uses a skinny type titania sensor think its like 12mm thread ... the other type is a fatty type zirconia wich is found on more modern cars also .... so make sure you do abit of research before you commit to buying one as the zirconia one will not fit or work .. ....
12 Re: O2 sensor on 25th May 2014, 12:42 pm
Turbazz
No I'm gonna try to clean it as Bob said to me on the phone with carb cleaner
13 Re: O2 sensor on 25th May 2014, 2:37 pm
What made you think it was shot ?
14 Re: O2 sensor on 25th May 2014, 6:53 pm
Turbazz
not giving me no reading
15 Re: O2 sensor on 25th May 2014, 7:12 pm
wires might have a break in even if you can not see it?
16 Re: O2 sensor on 25th May 2014, 7:37 pm
Do a continuty test that will tell you wether it has a broken wire or not ...
17 Re: O2 sensor on 25th May 2014, 7:39 pm
Turbazz
Could be did think of that.. I doubt it though
18 Re: O2 sensor on 25th May 2014, 7:41 pm
Turbazz
I was thinking of ordering special socket you get. I don't want to chew it
19 Re: O2 sensor on 25th May 2014, 8:33 pm
A decent spanner will do ...
20 Re: O2 sensor on 26th May 2014, 1:21 am
Turbazz
http://www.toolandfix.com/draper-55540-expert-22mm-3-8-square-drive-oxygen-sensor-socket.html?gclid=CNWFp4vrx74CFdShtAodczYAEg#product_tabs_review_tabbed
21 Re: O2 sensor on 26th May 2014, 1:22 am
Turbazz
Something like that I think it 17 though
22 Re: O2 sensor on 27th May 2014, 11:00 pm
Turbazz
http://www.ebay.co.uk/itm/Bosch-OXYGEN-O2-SENSOR-SKYLINE-R33-RB25DET-PULSAR-N14-N15-lambda-oxy-/300990503510?pt=AU_Car_Parts_Accessories&hash=item46146e9a56
Any good?
