Gtir Motorsport club » Tech room » Help and Advice » Oil drain for 3071r on standard manifold
1 Oil drain for 3071r on standard manifold on 2nd June 2014, 4:48 pm
What are people using to make up the oil drain for a 3071R on the standard manifold?
I need a drain flange and a fitting for the block.
I was thinking of something like or
for the flange but not sure of the neatest way to go from there as there isn't a lot of space.
Unfortunately the original flange and block fitting have been modified to accept a hose but the hose was so kinked it was almost closed so that's why I'm looking for a neater solution.
if your stuck short term use the hose from samco that can bend but dose not kink
