Gtir Motorsport club » Tech room » Help and Advice » O2. Sensor again
O2. Sensor again
1 O2. Sensor again on 4th June 2014, 11:15 pm
Turbazz
Previously I was not getting a reading so I decided to take it out...
Right so managed to get it out gave it a clean. Notice the wire was broken too! The red one. Soldered it up put it back together.
and now am getting a reading (using a Nissan software called tecu)
Now I'm driving my car it feels worser there is no top end power after 5500rpm!
Sensor voltage is hard to read as there is a delay. It goes up and down though..
What voltage reading should I get at idle?
My doubts are..
. Not tightened the sensor hard enough,
the washer needs replacing,
need to set my boost controller again(i'm not getting more than 0.9 used to get 1.1)
Sensor is fcuked
2 Re: O2. Sensor again on 4th June 2014, 11:20 pm
Turbazz
3 Re: O2. Sensor again on 4th June 2014, 11:21 pm
Turbazz
4 Re: O2. Sensor again on 4th June 2014, 11:21 pm
Turbazz
Red wire damaged!!
5 Re: O2. Sensor again on 5th June 2014, 7:51 pm
Spark plug spike
This link gives you detail how to check it
http://z32.wikispaces.com/Consult+Quick+Reference
6 Re: O2. Sensor again on 5th June 2014, 10:10 pm
Turbazz
Brilliant Spike. The information is really useful. But is z32 our car?
7 Re: O2. Sensor again on 5th June 2014, 10:24 pm
Turbazz
Also says we have two sensors?
8 Re: O2. Sensor again on 5th June 2014, 10:28 pm
No z32 is off a 300zx .... i think he means testing wise or method will be the same ..
9 Re: O2. Sensor again on 5th June 2014, 10:59 pm
Turbazz
Ahh yeh got you. Cheers guys
10 Re: O2. Sensor again on 17th June 2014, 9:47 pm
fudge
Mines acting very similar, my 02 sensor looks spot on and the wires are intact, I don't get any power and it struggles to rev to 5k Sad
11 Re: O2. Sensor again on 19th June 2014, 6:17 pm
Turbazz
Is your 02 sensor working? I am in power till 5k then its pants
12 Re: O2. Sensor again on 19th June 2014, 6:57 pm
Turns out it was a boost leak for elliots car mate but had similar thing to you ...
