Gtir Motorsport club » Tech room » Help and Advice » Temp gauge dropping on boost
1 Temp gauge dropping on boost on 19th June 2014, 8:41 pm
Hardy172cup
Ive noticed an odd problem when driving today, when I give it some the coolant temperature gauge goes mad, it will jump about like crazy and drop to the bottom when on boost but as soon as you let off it goes back to the normal position  Suspect
What do you think could be causing this? The car never over heats or anything, the temp gauge is just going a bit nutts when I give it some confused
2 Re: Temp gauge dropping on boost on 19th June 2014, 9:26 pm
Maybe its a bad earth mate ....
3 Re: Temp gauge dropping on boost on 19th June 2014, 9:28 pm
Hardy172cup
I'm thinking it must be an electrical fault of some sort to make it act like that lol
4 Re: Temp gauge dropping on boost on 19th June 2014, 11:01 pm
Yep seen this a few times sure the cure is to change the gauge in the clocks or check connection
5 Re: Temp gauge dropping on boost on 19th June 2014, 11:48 pm
Hardy172cup
As long as its no major issue then I don't mind it too much for the time being, I was just worried when I saw it drop because obviously temperature should stay pretty consistent
6 Re: Temp gauge dropping on boost on 20th June 2014, 8:57 pm
Gtirchris
Check the terminal on the sender unit mate, mine did the same and I found that the terminal was loose, I just soldered it up and it's been ok ever since. Smile
7 Re: Temp gauge dropping on boost on 21st June 2014, 1:39 pm
Turbazz
Do the fans kick in?
