Gtir Motorsport club » Tech room » Help and Advice » smokey smokey
smokey smokey
1 smokey smokey on 21st June 2014, 3:49 pm
So hathe he turbo re built ready for le man's and once all refitted took it for a spin and everything looked ok, didn't notice any issues straight away, slowly introduced some boost on the drive and after a little while I noticed some smoke and put it down to new parts burning off (turbo, elbow and exhaust) only the burning off never stopped, following day went for another spin and it smoked from start to finish and upon checking the oil I had gone through 4ltrs in 80 miles.
So far have put the blame on the turbo but a possibility I've done something to the engine.
Whipped the plugs out and cylinder 2 looks like it's been bathing in oil where as the others are clear, top of the piston appears to have oil on top of it and you can make out an indent ontop of the piston (maybe they all have but Couldnt see clearly on the others)
Have taken a compression test.
Cyl 1=172
Cup 2 =163
Cyl 3 = 155
Cyl 4 =163
Put the plugs back in swapping 2 and 3 over, went for a run to get warm none stop smoking the whole time on or off boost. When I removed the plugs Cyl 2 was black and 3 was now clean and you could make out oil ontop of the piston again
Compression when hot
Cyl 1 =155
Cyl 2=150
Cyl 3 =146
Cyl 4 =153
Going to take the turbo off tomorrow but any have any other faults or tell tale signs for me to look for.
2 Re: smokey smokey on 21st June 2014, 3:58 pm
when you first removed the turbo mark did you notice any oil around the ex ports in the head on any of the cylinders?
if so you may possibly have a cracked ringland or good be a dodgy valve stem oil seal but unless its almost cracked all the way through you should not get smoke like that, you generally get it on first start up and it dies off as sits in well of piston overnight
indent in middle of the pistons is meaning they are stock pistons
                                GTI-R-US.CO.UK
                                            'In association with'
                                          'Services provided'
3 Re: smokey smokey on 21st June 2014, 4:11 pm
Havent removed it yet, but last time round no it was all bone dry. Will have it off in the morning. Worried it's something with cylinder 2 but compression looks fine
4 Re: smokey smokey on 26th June 2014, 7:12 pm
So managed to get 30 minutes to whip the turbo off and here is what was hiding behind door number 2....well behind the manifold in cylinder 2
Sooo looks like someone is in need of a rebuild...but if I'm honest I'm at that unfortunate cross road in pulsar ownership of to be or not to be, that really is the question
5 Re: smokey smokey on 26th June 2014, 7:27 pm
You thinking its a ringland then mark ...
6 Re: smokey smokey on 26th June 2014, 7:50 pm
Certainly looks that way from what people have said but not going to know until it's stripped down
7 Re: smokey smokey on 26th June 2014, 8:29 pm
Get your head at eye level with the port mark and see if you can see oil running down the valve stem (one on the right) my guess is that's destroyed a stem seal as when a ring land goes it generally soaks the whole port at the bottom, with the pic you supplied it looks like it's only coming from rh side of port which would indicate a stem seal
In which case would be a fairly easy fix as you don't have to remove the head
                                GTI-R-US.CO.UK
                                          'Services provided'
8 Re: smokey smokey on 26th June 2014, 8:54 pm
Wouldnt it get worse as it gets hotter if its ringland as the crack would widen with heat ? But saying that if it was stem sills it would be the same as oil gets thinner in heat ? ...
9 Re: smokey smokey on 26th June 2014, 9:39 pm
Well I'm glad you say that because if it is a stem seal I'll be bringing it down to you to perform the operation as I wouldn't trust myself to do it in situ
10 Re: smokey smokey on 26th June 2014, 9:53 pm
I've got a special tool I can lend you mark  Wink
                                GTI-R-US.CO.UK
                                          'Services provided'
11 Re: smokey smokey on 26th June 2014, 9:57 pm
@GTI-R US wrote:I've got a special tool I can lend you mark  Wink
That's not nice calling Dave a special tool
12 Re: smokey smokey on 26th June 2014, 9:59 pm
goodpost
                                GTI-R-US.CO.UK
                                          'Services provided'
13 Re: smokey smokey on 27th June 2014, 8:03 pm
wanker didnt even see this post last night
14 Re: smokey smokey on 27th June 2014, 9:27 pm
You have to troll every post dave to see the nasty comments  Wink
