bool(false) Rally style - Page 3
Gtir Motorsport club » Gallery » Projects » Rally style
Rally style
Go down  Message [Page 3 of 6]
51Rally style       - Page 3 Empty Re: Rally style on 2nd December 2013, 10:24 pm
Glad it was only a dodgy battery mate, bet you can't wait to get behind the wheel lovely looking car.
What a result have the front loading tractor
52Rally style       - Page 3 Empty Re: Rally style on 2nd December 2013, 10:29 pm
Car looks great mate. If a tractor battery don't start it you really have got a problem Laughing  Thought that tractor was a New Holland at first but now I'm thinking Valtra?
53Rally style       - Page 3 Empty Re: Rally style on 3rd December 2013, 7:53 am
cheers lads
tractor is landini Smile
54Rally style       - Page 3 Empty Re: Rally style on 3rd December 2013, 4:47 pm
fred05
fred05
french connection
french connection
I love you I love you  i love it Tom!!!!
55Rally style       - Page 3 Empty Re: Rally style on 3rd December 2013, 5:50 pm
thanks Smile not many people do haha
56Rally style       - Page 3 Empty Re: Rally style on 3rd December 2013, 6:50 pm
Your joking tom i think it looks well smart ....Wink
57Rally style       - Page 3 Empty Re: Rally style on 3rd December 2013, 7:14 pm
Yes good effort i like it and as long as you do who cares what others think
58Rally style       - Page 3 Empty Re: Rally style on 3rd December 2013, 7:58 pm
no joke, most people think its quite brash and bold, they havent got the balls to drive it haha but as long as its works thats the main thing haha
59Rally style       - Page 3 Empty Re: Rally style on 7th December 2013, 9:39 pm
well finally after 2 1/2 years the car burst into life, along with 3 petrol leaks one being on the side of the tank Mad not fun when theres a diesel heater facing you Shocked Ive checked the timing but car still sounds rough very much like a proper rally car so not sure if the timings 100% but its getting smoother everytime i start her up, and she fires up instantly so cant far out.
Do have a few things not working 100% if anyone can shed some light on the following:
Wipers work but stop as soon as you flick them off, they dont finish there cycle to the bottom of the windscreen
No battery light in the dash (bulb in dash is fine as ive swapped them over) no light on either when running
cheers Tom
60Rally style       - Page 3 Empty Re: Rally style on 9th December 2013, 11:41 am
coming along nicely tom
with regard to the problems
check all your earths as that will cause both the above probs with wipers and alternator light, it can also make for lumpy idle if your only running on batt voltage
so make sure all earths are clean and connected or you could cause a spike in ecu
ps did you get the ex nuts?
61Rally style       - Page 3 Empty Re: Rally style on 9th December 2013, 5:27 pm
i did get the nuts but they didn't fit they were too small, so I ended up re- dieing the studs to fit some nuts i had here, but no worries.
Will check the earths tonight although i did clean them up before fitting  Rolling Eyes
Bob can you confirm ithe timing marks on the crank pulley for me, atm as you look down onto the pulley the cars running between the first and second mark closest the front of the car if that makes sense? is that right? thanks
62Rally style       - Page 3 Empty Re: Rally style on 10th December 2013, 10:48 am
are you using advance and setting to 20 degrees on the gun or are at 0 on the timing gun?
63Rally style       - Page 3 Empty Re: Rally style on 10th December 2013, 4:31 pm
0 on the timing gun bob, thats what it says in the manual, but as i said its between the first and second mark on the pulley and according to a few articles thats about right??? I also need to redo it tonight cos the car wont idle without me holding the throttle open so need to redo the procedure, is it safe to rev the car up a couple of times????
64Rally style       - Page 3 Empty Re: Rally style on 10th December 2013, 4:50 pm
ok yep if guns set to 0 then the last mark on the right would be 20 degrees which is about right.
check all your vacuum pipes to make sure ones not been left open and earth connections also.
if alternator is not charging and your running on batt voltage this can also cause a prob with idle issues so put a multimeter across the terminals and check voltage as should be at least 13.5v at idle.
yep once oil pressures up will be fine to rev it but do bare in mind it has new pistons/rings etc and been standing for months so don't rev the nuts off it from cold just rev it enough to keep her running till it gets upto temp then try making some adjustments on throttle bodies with idle etc to try stabilise her
65Rally style       - Page 3 Empty Re: Rally style on 10th December 2013, 5:00 pm
cheers bob It did idle ok on sat night at about 1000rpm but went to her last night and she kept conking out so i could'nt of tripped ecu or summit will look in a mo, also blow off valve vacuum isn;t helping need to connect it tonight thanks alot Smile
66Rally style       - Page 3 Empty Re: Rally style on 10th December 2013, 5:03 pm
just blank off vacuum to dv with a screw for the time being then that knocks that out the equasion of gremlins
just make sure any vacuum pipes that you are not sure about are blanked and not left open to atmosphere
67Rally style       - Page 3 Empty Re: Rally style on 10th December 2013, 5:08 pm
ah ok also I got the wipers working that turned out to be an earth, but any ideas about the indicator bulb?? indicators work fine just the right hand bulb doesn;t illuminate in the dash, ive checked the bulb and that fine???
68Rally style       - Page 3 Empty Re: Rally style on 22nd December 2013, 3:22 pm
most problems now (hopefully fixed) done my first mile in the car only 999 miles to go before spring Smile
Rally style       - Page 3 <a href=Rally style       - Page 3 DSCF1900_zps21cb6d5c" />
next major job is vinyls and sunstrip to be fitted in the new year (not too many though)  Cool
69Rally style       - Page 3 Empty Re: Rally style on 22nd December 2013, 6:49 pm
very nice looking car
70Rally style       - Page 3 Empty Re: Rally style on 22nd December 2013, 6:53 pm
Yeah!
I love the look of it B)
71Rally style       - Page 3 Empty Re: Rally style on 22nd December 2013, 7:30 pm
Gl3nnGTIR
Gl3nnGTIR
Looking good mate
72Rally style       - Page 3 Empty Re: Rally style on 22nd December 2013, 7:55 pm
Nice mate. Smile
73Rally style       - Page 3 Empty Re: Rally style on 22nd December 2013, 8:46 pm
Lovely work that really looks the part ... Wink
74Rally style       - Page 3 Empty Re: Rally style on 22nd December 2013, 9:03 pm
Is this the one your taking on the spa trip?
75Rally style       - Page 3 Empty Re: Rally style on 22nd December 2013, 9:25 pm
thanks lads
hopefully mate Smile
Back to top  Message [Page 3 of 6]
