Gtir Motorsport club » Tech room » Help and Advice » Changing tachometer
Changing tachometer
1 Changing tachometer on 2nd July 2014, 3:05 pm
grim_d
It would appear that my tacho is suffering from crazy needle syndrome.
Normally I would just change the whole dial unit for one of my spares but these are uk dials (with the clock!) and I would like to keep them.
So has anyone changed the tacho motor and have any tips for doing so? I would like to avoid breaking them. Any other areas to check that might be causing the problem? They worked fine in my last car I had them in but that was 5 years ago..
Cheers.
2 Re: Changing tachometer on 2nd July 2014, 4:58 pm
Some have had good results with contact spray on connectors & tiny bit of WD40 on the arms.
Never stripped a GTiR one so i'm not much help.
If you got a crappy import one spare you could use it as a test in good stripdown procedure.
Would indeed be shame ruin the uk style clocks as quite nice to have.
Someone on here added a digital clock to the JDM instruments so they may have some experience & tips on stripping the assembly.
3 Re: Changing tachometer on 2nd July 2014, 6:25 pm
Think that would be rob who did that ....
4 Re: Changing tachometer on 2nd July 2014, 7:08 pm
Whytie
I fitted the digital clocks into jdm gauges, easily done.
Usually when the rev counter does that it's down to a bad earth
5 Re: Changing tachometer on 2nd July 2014, 10:14 pm
grim_d
@Whytie wrote:I fitted the digital clocks into jdm gauges, easily done.
My mate who is a bit of a whizz with electronics said it would be a bad earth tonight. A dry solder joint or something?
Might get them out over the weekend for a look.
