Gtir Motorsport club » Tech room » Help and Advice » Gtir diograms/ shell
1 Gtir diograms/ shell on 9th July 2014, 6:49 pm
Samgtir
Hi
Can any one point me in the right direction to find some diagrams of how the shell is put together , I'm mainly looking for the front right chassis leg. Really need to get this bent leg sorted out.
2 Re: Gtir diograms/ shell on 9th July 2014, 7:20 pm
http://nissan4u.com/parts/sunny/el_n14/1991_1/type_49/axle_suspension_and_steering/front_axle_and_front_suspension/
3 Re: Gtir diograms/ shell on 9th July 2014, 7:40 pm
If you pop down mine with an angle grinder I've a shell down here where you can cut a straight leg from
4 Re: Gtir diograms/ shell on 9th July 2014, 8:12 pm
Samgtir
Perfect bob, I will be down next week , I have a job locally . Top man
5 Re: Gtir diograms/ shell on 9th July 2014, 8:12 pm
Same as sam .... although i would think bob is slightly closer to you than me ...
6 Re: Gtir diograms/ shell on 9th July 2014, 9:08 pm
Samgtir
I think it's the way forward, the car is immaculate except for that leg, the front drivers side wheel is 1-2 cm out, angry at myself I dint spot it but it's only noticeable from underneath
7 Re: Gtir diograms/ shell on 9th July 2014, 9:10 pm
Yeah if you wanna pop down and cut it off Sam you can have it fella if it helps you out
8 Re: Gtir diograms/ shell on 10th July 2014, 10:51 am
Samgtir
Top man I will be down soon
