Gtir Motorsport club » Tech room » Help and Advice » Over heating
Over heating
1 Over heating on 20th July 2014, 4:12 pm
Gti-r dannyboy
The engine is over heating plus the fans on the rad aint turning on.
Any ideas?
I have checked the fuses and the fans definitely work.
2 Re: Over heating on 20th July 2014, 4:33 pm
gtir350
Air lock in cooling system. Are you still runing the motec ECU ?
3 Re: Over heating on 20th July 2014, 4:34 pm
Coolant temp sensor maybe ????
4 Re: Over heating on 20th July 2014, 4:38 pm
Is rad getting hot, thermostat working ok.
need check sensor etc for fans fully ...
5 Re: Over heating on 20th July 2014, 4:44 pm
Gti-r dannyboy
Yeah still the motec  ecu. Where  can i find the coolant senser?
Dont think is the thermostat as it was fine b4 i swap the engine.
6 Re: Over heating on 20th July 2014, 4:48 pm
Gti-r dannyboy
Leighton took the pulsar out on the road for the first time today drives and sounds sweet just a couple of minor issues to sort out.
7 Re: Over heating on 20th July 2014, 4:48 pm
How quickly does it get hot ..?
8 Re: Over heating on 20th July 2014, 4:54 pm
Gti-r dannyboy
had it ticking over for 5minutes,wel i put some air in the tyres.
Then maybe 5-6mins drive, a very steady drive.
9 Re: Over heating on 20th July 2014, 4:57 pm
Gti-r dannyboy
Give me a few mintues and a will post a pic of a wire
Near the rad but i dont think its has anythink to do with it.
10 Re: Over heating on 20th July 2014, 5:03 pm
Gti-r dannyboy
11 Re: Over heating on 20th July 2014, 6:08 pm
@Gti-r dannyboy wrote:Yeah still the motec  ecu. Where  can i find the coolant senser?
driver side of the engine bay just below the brake master cylinder. You'll see metal pipe leading to the inlet manifold with two connectors on it one is water temp - gauge, the other is the ECU coolant sensor ( the one with 2 pins)
Certainly expect it minor wiring issue.
12 Re: Over heating on 20th July 2014, 6:13 pm
Gti-r dannyboy
Thanks mr b i will hav alook in the morning
13 Re: Over heating on 20th July 2014, 7:58 pm
Yeah if the sensor is either not plugged in or is faulty the ecu will also have no feedback of engine temp so you could have fuelling probs
Seeing as you've had the lump out I would take a good look at the connections on the ecu loom aswell as although the temp sensor to ecu is on the rear loom they are connected as it's the earth that is a trigger wire for the fans so if sensor does not work after testing it your gonna have to check right back on the other loom too on top of the gearbox as one of those connections carries the trigger wire for fans.
Or just fit an aftermarket fan controller if you can't find it
14 Re: Over heating on 20th July 2014, 9:38 pm
I think the wire in the pic went to the aircon rad.
15 Re: Over heating on 20th July 2014, 9:49 pm
I thought the trinary switch was the other side ???
16 Re: Over heating on 21st July 2014, 5:30 pm
I looked at the pic for a long time and decided the pic was the passenger side. Question
If it's the other side then don't know.  Exclamation
If it's somewhere near the middle along the front then it could be the connection the the aircon air temp sensor...
17 Re: Over heating on 21st July 2014, 7:04 pm
Gti-r dannyboy
I think it must be aircon, with never owning a pulsar with aircon i never new where the aircon was in there first place, just with it being near my rad thought it could be something with car over heating.
18 Re: Over heating on 21st July 2014, 7:22 pm
So you got any further with this danny ???
19 Re: Over heating on 21st July 2014, 7:41 pm
Gti-r dannyboy
Not yet mate been called away to Dundee with work so not going be back till friday, but at least i will have the hole weekend to have a mess, if i crnt crack it mite just wire them up to a switch bcus i want put it in for mot next week.
20 Re: Over heating on 21st July 2014, 10:09 pm
Yeah its always an alternatives if you cant figure it out ...
21 Re: Over heating on 24th July 2014, 5:37 pm
Gti-r dannyboy
Just had a quick look under bonnet and there seems to be a lil peg just above the oil filter with nothing onit, could this be anything to do with it over heating?
22 Re: Over heating on 24th July 2014, 5:46 pm
Spark plug spike
Yes mate the wire is missing for the ECU temp sensor so the fans will not kick in without it connected
23 Re: Over heating on 24th July 2014, 6:24 pm
Gti-r dannyboy
I will jack the car up saturday morning and see if i can find the missing wire.
24 Re: Over heating on 24th July 2014, 6:38 pm
Spark plug spike
Here is a pic of mine, my connector was missing so I just crimped a spade connector on.
25 Re: Over heating on 24th July 2014, 6:38 pm
You might of tucked it out the way when you was doing the engine swap ....
