My R
Go to page : 1, 2, 3 ... 12 ... 23  Next
Go down  Message [Page 1 of 23]
1My R Empty My R on 22nd July 2014, 10:24 pm
Thought id post up some of the specs of my car. I started this build over 2 years ago and basically started with a standard R, its currently almost ready for its first tune Smile
Suspension and Wheels
BC Coilovers
Whitleline rear swaybar
Rear strut brace
Stance Mindset wheels 15x8 +25
Rubber 195/50
Engine Specs
Block, Bored and Honed
Head serviced, cleaned, value clearances checked, ported and polished
Fully balanced, linished and crack tested crank
ACL Race Bearings
ARP Head and Main bolts
Scat Conrods
SRP Pro Pistons & Rings 87mm (Ceramic coated)
Ferrea stainless exhaust valves
Crower Value Springs and titanium retainers
Tomei Head Gasket
Vison Adj Cam Gears
Custom Cams (build by surecam in Sydney)
Genuine new Timing Chain Kit
Genuine new Oil Pump
Genuine new water pump
Single throttle body conversion
Alternator relocated
MR2 electric power steering pump
PPG Synchromesh Straight Gearset with billet 3/4 selector fork
Nismo Rear Diff
Gearbox Brace
Half Cage
Single 044, Surge Tank, Sard Fuel Reg, 550cc Injectors (bigger fuel system is needed before tune)
6Boost Manifold
Tial 38mm wastegate
Garrett 3076r .63
Microtech ECU
Currently plans are to upgrade the fuel system and use e85. Undecided on the size of injectors needed yet......
A few pics Smile let me know what you think Smile Chris
My R IMAG0085
My R IMG_20111016_00007_NEW
My R Photo10
2My R Empty Re: My R on 23rd July 2014, 12:19 am
grim_d
grim_d
That is quite a spec and nice to see all the supporting mods, what ignition system are you running?
What power do you hope to achieve?
Very nice.
3My R Empty Re: My R on 23rd July 2014, 1:42 am
@grim_d wrote:That is quite a spec and nice to see all the supporting mods, what ignition system are you running?
Very nice.
Im using microtech ignitor box with bosch coils and still using the standard distributor for a crank angle signal. After upgrading fuel system my aim is 450hp atw but I would be happy with anything around the 400 mark Smile
4My R Empty Re: My R on 23rd July 2014, 5:19 pm
KF79GTIR
On standard bakes? If so your a brave man...affraid
5My R Empty Re: My R on 23rd July 2014, 5:39 pm
GTIR James
Looks a lovely spec. Nice attention to detail. Love to fuel swirl pot setup. Good work.
6My R Empty Re: My R on 23rd July 2014, 9:28 pm
@KF79GTIR wrote:On standard bakes? If so your a brave man...affraid
Yup on standard brakes at the moment  lol! will be upgrading shortly, once I know everything is running good, one step at a time Smile
7My R Empty Re: My R on 23rd July 2014, 9:37 pm
@GTIR James wrote:Looks a lovely spec. Nice attention to detail. Love to fuel swirl pot setup. Good work.
Thanks mate Smile I like the swirl pot setup aswell but it needs to change to an underbody one shortly. Current setup is difficult to get engineered in aus Sad
8My R Empty Re: My R on 23rd July 2014, 10:22 pm
I think bogdan was going to make some or could make you one ....
9My R Empty Re: My R on 23rd July 2014, 10:24 pm
10My R Empty Re: My R on 24th July 2014, 1:26 am
Thanks mate! I'll have a look. Aeroflow also do a twin pump undercar surge tank I've been looking at. Anyone have opinions about injectors? I'm going to run e85 and was looking at 1600cc injectors. I think I'll go with Bosch Indy Blues (low impedance) or alternatively Bosch do another 1600cc injector that's high impedance. Any opinions or other brands I should look at?
11My R Empty Re: My R on 24th July 2014, 5:17 pm
1600cc thats pretty huge ive seen big power cars running 1000cc injectors never that big though ....
12My R Empty Re: My R on 24th July 2014, 11:32 pm
@nomad wrote:1600cc thats pretty huge ive seen big power cars running 1000cc injectors never that big though ....
I would have thought the same, but remembering e85 uses more fuel. I used this calculator to get a rough idea. I entered 550hp at the wheels to ensure I have room to move in the future. The figure I got was 1549cc being required. Interesting if anyone disagrees as this is the first time I've been trying to estimate a required injector size Smile
http://fuelinjectorclinic.com/flow-calculator
13My R Empty Re: My R on 25th July 2014, 6:01 am
watoga
watoga
ecu technician
ecu technician
@gtir_woody wrote:Im using microtech ignitor box with bosch coils and still using the standard distributor for a crank angle signal. After upgrading fuel system my aim is 450hp atw but I would be happy with anything around the 400 mark Smile
That is definitely a nice GTiR; your engine bay is lovely  Cool
Out of curiosity, when you switched over to the ignitor box did you remove the OE condenser and power transistor? Or do you simply trigger the ignitor box from the OE coil +/- wires with the condenser and power transistor still attached?
Looks very nice!
Dave
14My R Empty Re: My R on 25th July 2014, 6:22 am
fred05
fred05
french connection
french connection
impressive car, it looks so fat with thos rims and buble tyres, and an adapted lowering!!
really really love that kind of look
15My R Empty Re: My R on 25th July 2014, 7:31 am
Looks very nice!
Dave
Thanks a lot dave!! Yup all removed, So I'm using a microtech which is a standalone ecu, unlike some other ecu's actually have the ignitor box as a separate module which connects to the ecu for running a multi-coin setup like mine. So none of the original wiring, power transistor etc remains.
16My R Empty Re: My R on 25th July 2014, 7:33 am
@fred05 wrote:impressive car, it looks so fat with thos rims and buble tyres, and an adapted lowering!!
Thanks mate, really love the look of it. I will run different wheels and tyres though when it's eventually on the track Smile
17My R Empty Re: My R on 25th July 2014, 10:28 pm
E85 fuel... would you have to renew all fuel lines etc .... judging by the pulsar fuel economy as standard so reckon with e85 it gets some proper low mpg .... you will become on first name terms with the petrol garage lol ...
18My R Empty Re: My R on 26th July 2014, 1:30 am
Very nice Smile looks sweet with them offset wheels & sounds like a good setup car Wink
19My R Empty Re: My R on 26th July 2014, 3:43 am
 What a Face
@nomad wrote:E85 fuel... would you have to renew all fuel lines etc .... judging by the pulsar fuel economy as standard so reckon with e85 it gets some proper  low mpg .... you will become on first name terms with the petrol garage lol ...
My understanding is all the standard rubber fuel lines needs to be replaced as e85 is very corrosive. I've actually already replaced the lines for my current setup but need to check they are compatible. Haha the petrol station would love me! But lucky for me this isn't a daily driven car Smile
20My R Empty Re: My R on 27th July 2014, 11:27 am
Thought id post some old pics of my alternator and power steering step up. Main reason I moved the alternator (to where the power steering pump is normally) was I wanted to allow more room for my dump pipe. I used information over on the SR20-Forum. Fairly easy job requiring some grinding of the PS bracket, alternator mounts and minor cutting/ welding of the adjustment bracket.
My R Image
However that left me with no power steering, rather than feel like Im going to gym everytime I drive my car I decided to use an electric power steering pump from an MR2.
As I've yet to drive the car it should be interesting to see how the steering performs. My main concern was how much power the pump will draw, but a few threads I found people didnt have any major problems on other cars. Im running the pump off a switch so I can turn it off when its not needed. As the pump has its own ECU it can also be wired to the speed sensor and the voltage will drop at greater speeds. Anyway thought some of you might find that half interesting Smile
My R Photo_2
21My R Empty Re: My R on 27th July 2014, 7:43 pm
Good work fella
Car looks great but wills be a bitch to change the alternator if it ever packs up
22My R Empty Re: My R on 27th July 2014, 9:12 pm
just what I was going to say I have a bracket to do this but decided not to for the above reason
23My R Empty Re: My R on 27th July 2014, 9:29 pm
Yeah it is a massive pain in the arse, let's hope I have a good alternator then haha
24My R Empty Re: My R on 11th August 2014, 6:53 am
Dropped the car off for a run in tune today. Starting on low boost just so I can drive around. Hopefully nothing breaks  Shocked
25My R Empty Re: My R on 11th August 2014, 6:43 pm
good luck keep us posted
Back to top  Message [Page 1 of 23]
