Gtir Motorsport club » Tech room » Help and Advice » Shocks
Shocks
1 Shocks on 9th August 2014, 8:17 am
Would gti shocks be the same as gtir as I'm going to fit new ones this winter and whenever I ask for gtir stuff they just look at me blank lol
2 Re: Shocks on 9th August 2014, 11:15 am
I think they are the same other than the rear strut where the drop link bolts is different on the gti ...
3 Re: Shocks on 9th August 2014, 2:08 pm
I thought the rears were completely different to gtir but im not 100% on that if im honest
4 Re: Shocks on 9th August 2014, 3:00 pm
If aiming for pretty much standard you may find going to Nissan works out okay, did have prices around £120 a strut but was some time ago but worth a call/visit.
You probably will find the 4x4 cars the best options for trying cross fit struts.
KYB will have good range of stuff that probably will work/require minimal tweaks if no direct part listing is possible.
5 Re: Shocks on 9th August 2014, 11:36 pm
I've given up with my local nissan. After 8 calls I'm still waiting for a price on a standard exhaust and that was 16 months ago. lol when I get them off I'll have a measure up and try to find a comparison
6 Re: Shocks on 10th August 2014, 9:34 am
Do you not have more than 1 dealer in your area so you could at least get a current price idea.
I have the numbers 'below' of KYB struts that are said to fit the GTiR but I have not tried myself as used new from nissan on one & been able find decent GABS then refreshed with new paint, boots, tophats & custom springs from springcoil modelled from original GAB springs for some others.
These numbers may help narrow selection from a local autofactors ...
KYB (excel G)
front: kyb333091, kyb333092
rear:  kyb339001, kyb339002
7 Re: Shocks on 10th August 2014, 6:26 pm
this is a pic of the gti rear struts .... 68quid off ebay
8 Re: Shocks on 10th August 2014, 7:59 pm
Trouble with gti rears is body tube hangs too low & catches the cv joint & as stated the drop link bracket point is not same.
9 Re: Shocks on 10th August 2014, 8:08 pm
I was meerly showing the difference .... is the housing larger then ????
10 Re: Shocks on 10th August 2014, 8:14 pm
gti protrudes more below hub mounting point & is about 25mm longer in body over gtir strut, housing diameter is same.
11 Re: Shocks on 10th August 2014, 8:54 pm
Presumebly because they do not have to worry about the rear diff on the gti ... you would of thought they would of made the same struts for all to save on cost ...
12 Re: Shocks on 10th August 2014, 10:00 pm
http://m.mister-auto.co.uk/en/front-shock-absorber-nissan-sunny-mk-iii-hatchback-n14-2-0-gti-r-4x4-220hp_v4517_g900001.html
13 Re: Shocks on 11th August 2014, 9:48 am
@nomad wrote:Presumebly because they do not have to worry about the rear diff on the gti ... you would of thought they would of made the same struts for all to save on cost ...
Basically no drive shaft passing under base of strut allows space for strut hang lower, was surprised myself when first saw it as like you would of expected high chance of externals of strut being same for easier/cheaper manufacture. Other factor would of been that fwd was designed first for the model range.
Front shocks are easier as the standard fwd gti struts bolt straight on.
KYB 633116 - 633115
Application:
100 NX (B13)  1990/03 - 1994/10
 100 NX (B13) 1.6 GA16DS    1990-03-00 1994-10-01
 100 NX (B13) 1.6 SR GA16DE    1993-09-00 1994-10-01
 100 NX (B13) 2.0 GTI SR20DE    1991-03-00 1994-10-01
 SUNNY III (N14)  1990/05 - 1995/12
 SUNNY III (N14) 1.4 i GA14DS    1990-10-00 1995-05-01
 SUNNY III (N14) 1.4 GA14DS    1990-10-00 1995-06-00
 SUNNY III (N14) 1.6 i GA16DS    1990-10-00 1995-05-01
 SUNNY III (N14) 1.6 i 16V GA16DE    1992-10-00 1995-05-01
 SUNNY III (N14) 1.6 i 16V 4WD GA16DS    1990-10-00 1995-05-01
 SUNNY III (N14) 2.0 D   CD20    1990-10-00 1995-05-01
 SUNNY III (N14) 1.6           1990-08-01 1994-10-01
 SUNNY III (N14) 2.0           1990-08-01 1994-10-01
 SUNNY III (N14) 1.6  4x4           1992-10-01 1995-06-01
 SUNNY III Hatchback (N14)  1990/10 - 1995/07
 SUNNY III Hatchback (N14) 1.4 i GA14DS    1990-10-00 1995-05-01
 SUNNY III Hatchback (N14) 1.4 GA14DE    1990-10-00 1995-06-00
 SUNNY III Hatchback (N14) 1.6 i GA16DS    1990-10-00 1995-05-01
 SUNNY III Hatchback (N14) 2.0 D   CD20    1990-10-00 1995-05-01
 SUNNY III Hatchback (N14) 2.0 GTI 16V SR20DE    1990-10-00 1995-05-01
 SUNNY III Hatchback (N14) 2.0 GTI-R 4x4 SR20DET    1990-10-00 1995-05-01
Personally best choices if keeping vehicle standard as possible are new from nissan followed by decent set of used GABs .
You can put koni or bilstein cartridges in standard struts but not cheap to do well.
