Gtir Motorsport club » Tech room » Help and Advice » Water temp gauge sender
1 Water temp gauge sender on 11th August 2014, 9:51 am
Gtir.si
Hi what's the best place to put an after market water gauge sender . The original sender is a different thread and can't get an adaptor to fit . Thanks
2 Re: Water temp gauge sender on 11th August 2014, 10:06 am
What type of sender you using? I was using a mechanical gauge at one stage and made up an adapter to fit between the radiator hoses. Im sure they have them on ebay. Or you just mean an aftermarket sensor for the standard gauge?
3 Re: Water temp gauge sender on 11th August 2014, 11:03 am
Gtir.si
It's a electric one for an Apexi gauge . They have adaptors what you cut your hose but there isn't enough room on the top hose for it . May have to mod something by the sounds of it cheers
