Gtir Motorsport club » Gallery » Projects » My VET Build
My VET Build
Go to page : Previous  1, 2, 3, 4, 5, 6
Go down  Message [Page 6 of 6]
126My VET Build - Page 6 Empty Re: My VET Build on 24th November 2017, 12:27 pm
Must of been fun and demanding being the mapper on the session.
that almost 325horses and 360torque in old colonial numbers .
are you keeping internals standard or planning on some internal parts down the road .
any thoughts on using water injection.
127My VET Build - Page 6 Empty Re: My VET Build on 24th November 2017, 2:05 pm
325 ... was a lot less than I thought then ...
128My VET Build - Page 6 Empty Re: My VET Build on 24th November 2017, 9:10 pm
@nomad wrote:325 ... was a lot less than I thought then ...
Works out to be 410bhp at motor and 360ftlbf
129My VET Build - Page 6 Empty Re: My VET Build on 24th November 2017, 9:24 pm
@Mr B wrote:Must of been fun and demanding being the mapper on the session.
Yeah was fun and was a little nervous, plan is to fit the dog box and go back for more more boost and timing. Has plenty left in it. We have E85 locally so will use that once the 98 fuel map is done.
Stock internals will hold 300kw. But I have some engine internals stored away if needed.
130My VET Build - Page 6 Empty Re: My VET Build on 24th November 2017, 9:43 pm
Great result mate pleased for you
131My VET Build - Page 6 Empty Re: My VET Build on 24th November 2017, 10:23 pm
Sorry I didn't realise you mean atw's I thought you meant total bhp ...
132My VET Build - Page 6 Empty Re: My VET Build on 25th November 2017, 12:44 am
These links should work
https://redcdn.net/ihimg/a/img923/6479/FKGvLh.png
https://redcdn.net/ihimg/a/img923/4719/nHwIqv.jpg
My VET Build - Page 6 FKGvLh
My VET Build - Page 6 NHwIqv
133My VET Build - Page 6 Empty Re: My VET Build on 24th December 2017, 8:26 am
Ryaneg6freak
Ryaneg6freak
Why the p12 Cams Nigel? I always thought the stock VET cams were better optimized for boost?
134My VET Build - Page 6 Empty Re: My VET Build on 26th December 2017, 10:42 am
Some say p12 intake and vet exhaust give better results. But I can't see how if you run adjustable cam gears on the p12 pair. Both are hard to get so it's better nowadays buying a custom kit.
135My VET Build - Page 6 Empty Re: My VET Build on 27th December 2017, 7:10 am
Ryaneg6freak
Ryaneg6freak
@ducie54 wrote:Some say p12 intake and vet exhaust give better results. But I can't see how if you run adjustable cam gears on the p12 pair. Both are hard to get so it's better nowadays buying a custom kit.
Just out of curiosity, you said you had to add the VVl exhaust solenoid from the P11, I assume to get the exhaust rockers to engage that you added. I can't remember for sure, but didn't the Xtrail VET combine both solenoids into one?
136My VET Build - Page 6 Empty Re: My VET Build on 28th December 2017, 9:49 am
The VET only has switched rockers on the intake so I used another 4 from a spare p11 head I had. VET head also only has a single solenoid which is fine as it will switch both sides. You can use the P11 solenoid but it needs to be modified.
137My VET Build - Page 6 Empty Re: My VET Build on 29th January 2018, 10:05 am
Its amazing what some cold air does. 16 psi @ 4200 on a GTX3076 .82
My VET Build - Page 6 ZpWJbm
138My VET Build - Page 6 Empty Re: My VET Build on 29th January 2018, 8:18 pm
What does this mean lol ....
Back to top  Message [Page 6 of 6]
