Gtir Motorsport club » Tech room » Help and Advice » Tappy head???
Tappy head???
1 Tappy head??? on 18th August 2014, 2:41 pm
hi, got a little issue ive noticed, when driving the car there is a consistent tapping/ fast ticking sound coming from engine which sort increases with the revs of the car, no other issues with car everything still boosts and works as it should its just an annoying noise.
could this be the head which is the issue and how do i fix it if i can myself?
2 Re: Tappy head??? on 18th August 2014, 5:15 pm
Top or bottom end ? Prob hard to tell if driving. Dose it do it when standing still if you rev it ? Any difference in oil pressure ? Without scare mongering its either bottom end. Shims or oil starve to the head maybe ?
3 Re: Tappy head??? on 18th August 2014, 5:30 pm
As johny said above... Also if its a ticking, could well be injector ticking... But all depends on how it sounds?
4 Re: Tappy head??? on 18th August 2014, 6:13 pm
I did think that gaz but to hear them when driving must be quiet loud. But also thought he might of noticed them previous
5 Re: Tappy head??? on 18th August 2014, 6:52 pm
If its shims it should get louder as it gets warmer .... could also be a gasket leak like manifold etc .......
6 Re: Tappy head??? on 18th August 2014, 7:30 pm
Sounds like its from the head and its a more higher pitched when im in car, got the missus to rev and i listened its sound like a timing chain sort if rattle
7 Re: Tappy head??? on 18th August 2014, 7:57 pm
Maybe the tensioner starting to go or guide worn bob would know more about it than me
8 Re: Tappy head??? on 18th August 2014, 8:43 pm
Damn is that an engine out job?
9 Re: Tappy head??? on 19th August 2014, 7:47 am
Took it to work today and tge noise seems to start at about 2000rpm and it gets louder as i accelerate, doesnt do it at idle like i initially thought
10 Re: Tappy head??? on 22nd August 2014, 7:37 pm
Spark plug spike
Hope it's not the same issue as mine see this link
http://www.gtir-motorsport-club.com/t3617-ticking-knocking-noise
Mine turned out to be a spun big end bearing on No3 rod which was making the noise
11 Re: Tappy head??? on 2nd September 2014, 1:30 pm
I had a listen to your video and its not the same sort of noise i get with mine, mine is more of a ticking
