Gtir Motorsport club » Tech room » Help and Advice » 3" inch janspeed downpipe
1 3" inch janspeed downpipe on 22nd August 2014, 5:00 pm
Wazza
Can anyone help. Fitted 3 inch janspeed elbow and down pipe but the lambda sensor doesn't fit...
Anyone fitted one before??
2 Re: 3" inch janspeed downpipe on 22nd August 2014, 8:23 pm
Dose not fit how ? Thread ? Size of hole. Sensor is to long for wher the boss points ?
3 Re: 3" inch janspeed downpipe on 23rd August 2014, 12:21 am
Wazza
The whole is too wide for the sensor. Had to cut off the bolt and weld a new one to fit the sensor.
4 Re: 3" inch janspeed downpipe on 23rd August 2014, 1:07 pm
they generally only come with a wideband boss for aem ect
you can unscrew the narrowband boss from original elbow then just weld it into the pipe
if your going to use an aftermarket ecu such as power fc ect many of these don't use the narrowband lambda when being mapped as there mapped from idle all way through so youll only use the wideband
5 Re: 3" inch janspeed downpipe on 23rd August 2014, 1:20 pm
Wazza
thats what we did tar bob, hope u had a good time on ya hols btw Smile
oh well gives him another job when we get an ecu haha
6 Re: 3" inch janspeed downpipe on 23rd August 2014, 1:59 pm
I had this problem with my downpipe so I found a bolt at work and cut the thread off it. I then tapped a thread down the centre for the lambda down the centre and welded it in.
