Gtir Motorsport club » active members adverts » Parts Wanted » Cluster
Cluster
1Cluster  Empty Cluster on 6th September 2014, 6:20 am
Chasing a series 1 cluster in working order. Has to be km/h Very Happy
2Cluster  Empty Re: Cluster on 6th September 2014, 9:48 am
ask it to slow down a bit and you may catch it
anyway you should be half way to England now with my car so whats going on? hope this isn't some kind of scam
il look for you but think I only have phase 2 clocks, is it abs or non abs?
3Cluster  Empty Re: Cluster on 6th September 2014, 11:10 am
Haha the only scam will be if you're not there holding that candle Laughing
It's the non-abs one, with the anti-lock symbol.
Main reason is speedo is broken in my current one
4Cluster  Empty Re: Cluster on 6th September 2014, 3:39 pm
mmmmm! so you do have abs
I know for a fact I don't have any antilock clocks but if you use abs clocks all you need to do is swap the circuit board over from your antilock ones onto the abs ones, that's the only difference between the two is the wiring track
5Cluster  Empty Re: Cluster on 6th September 2014, 11:00 pm
Ahh yes got abs! I've been looking for an anti-lock one for awhile and they never come up.
Looks like I'll give changing the circuit board over, got a few working ones there bob?
6Cluster  Empty Re: Cluster on 6th September 2014, 11:02 pm
Il have a look for you Monday mr woody
If I forget then drop me a pm to give me a kick up the ass
7Cluster  Empty Re: Cluster on 6th September 2014, 11:38 pm
Thanks mate, if you end up having one, there are a few other bits and pieces I'm chasing that you'll probably have Smile
8Cluster  Empty Re: Cluster on 6th September 2014, 11:57 pm
So tell me whats the difference do you have a pic or something ???
9Cluster  Empty Re: Cluster on 7th September 2014, 12:52 am
From memory visually they look the same but the series 1 has an antilock symbol and the series 2 is replaced with an abs symbol. That's how you can easily tell the difference. The problem is the circuit boards on the back are different. So they aren't directly interchangeable between the series. I'll see if I can find some pics.
10Cluster  Empty Re: Cluster on 7th September 2014, 3:41 am
Not the best photo but you can see the different in the circuit boards
Series 1 on the left, series 2 on the right
Cluster  Post_80_13257357937942
GTIROZ for photo credit
