Gtir Motorsport club » Tech room » Help and Advice » Oil pick up
Oil pick up
1 Oil pick up on 12th September 2014, 6:52 pm
gtir_sunny
Might be a stupid question but is there a gasket of some sort between the oil pick up and oil pump
2 Re: Oil pick up on 12th September 2014, 8:25 pm
blacklet
There's a o ring between the pick up and pump.
3 Re: Oil pick up on 13th September 2014, 6:44 am
yes as above o ring or you can now buy gaskets with a pressed bit that goes wher o ring is
4 Re: Oil pick up on 13th September 2014, 7:34 am
gtir_sunny
Thanks for the replys, johnny do you have a link to the pressed gasket mate
5 Re: Oil pick up on 13th September 2014, 7:47 am
http://www.ebay.co.uk/itm/like/251578142610?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108
6 Re: Oil pick up on 13th September 2014, 7:48 am
that was just first one I found not saying its the exact one. not sure weather this one kees the rubber o ring as well. a lot just use rubber o ring and a tiny bit of sealer
7 Re: Oil pick up on 13th September 2014, 9:35 am
Gasket in link is for flat machined flange type not the O-ring groove type flange strainer.
Just use OEM O-ring ...
