Gtir Motorsport club » Tech room » Help and Advice » Wildwood brake help
Wildwood brake help
1 Wildwood brake help on 19th September 2014, 1:23 pm
houghy_1
Hi guys, Ive got the 280 x24 4 pot kit from wilwood.
I be git a cracked front brake disc so I'll be wanting new discs and pads. What I want to know is can I.use my midlite caliper with the 310 bell and rotor set up, even though there 310 x 21???
Is it possible or do I need a different piston?
I.git the kit from rally design years ago.
Ta.
2 Re: Wildwood brake help on 19th September 2014, 2:13 pm
mreguest
I think you can use the same caliper but need a different adapter bracket to make the caliper further out from centre. Ask wilwood.
With regards to the disk being 21mm rather than 24mm, so only 3mm thinner you will have no trouble, think about how thick new brake pads are compared to how low they can get. it would only equate to 1.5mm thickness each side.
i think the 280mm front disks are off a clio sport 172/182 i believe, also some of the meganes and espaces i think, so like £50 a pair... I have the same 280mm willwood front kit. Being an american company have you noticed the front bleed nipples are 1/4" spanners! inbetween 6mm or 7mm. Me and friend had already emptied the system before realising so hammered a 7mm spanner thinner...
bleed from the top, do not bleed from the bottom!
let us know what you find out about the 310mm.
good luck!
Adam
3 Re: Wildwood brake help on 19th September 2014, 3:03 pm
houghy_1
Yeah most of that I know,I've not looked into exactly which Clio it would be but that would give me more options,ta
I'm.only asking cos I rang up rally designs last year and the guy I spoke to said " ooh no you can't do that there different thickness discs" to which I pointed out that both kits use the same bloody caliper. So I only wondered if they just used a different size or length piston. And 1/4" is 6.35mm by the way ;-)
I'll try n blag the bells from them and I'll sort the adaptors out myself,being a Cnc machinist ;-)
4 Re: Wildwood brake help on 19th September 2014, 7:11 pm
The grand scenic uses 300mm x 4 stud discs ....
5 Re: Wildwood brake help on 19th September 2014, 7:18 pm
http://pages.ebay.com/link/?nav=item.view&id=130944520388&alt=web
