Gtir Motorsport club » Tech room » Help and Advice » Speed sensor wiring
Speed sensor wiring
1 Speed sensor wiring on 8th October 2014, 12:39 am
Just wanted to confirm that I can wire the speed sensor directly to the main clocks bypassing the ECU? Im using an aftermarket ECU by the way, so ditching the stock ecu completely
2 Re: Speed sensor wiring on 8th October 2014, 6:40 pm
Can you not just take tap into the wire from the stock plug its pin 2 iirc ....although i dont see it being a problem from the back of the clocks ...
3 Re: Speed sensor wiring on 8th October 2014, 8:59 pm
Ok thanks Smile. Which plug? All the standard ecu wiring and plugs are gone now. I only figured out the speedo problem after I had cut most of it out Laughing
4 Re: Speed sensor wiring on 8th October 2014, 9:16 pm
Sorry didnt realise you had got rid of the main ecu plug so here is the cluster pinout for you ...
5 Re: Speed sensor wiring on 8th October 2014, 9:20 pm
Sticky the pic please in the diagrams section
6 Re: Speed sensor wiring on 8th October 2014, 9:29 pm
Thought you would like that one ....All done and added into my diagrams post.
7 Re: Speed sensor wiring on 8th October 2014, 9:55 pm
Excellent thanks guys Smile
8 Re: Speed sensor wiring on 8th October 2014, 10:21 pm
Your welcome mate .... hope it goes well .... what ecu are you running now ???
9 Re: Speed sensor wiring on 8th October 2014, 10:33 pm
I'm currently using a microtech with a multi-coil setup, they are an Australian company. The modelI have is outdated now. I'm going to move to a haltech when I iron out all the little problems that come with building a new car Smile
