Gtir Motorsport club » Gallery » Projects » And it begins. Robs big pulsar rebuild
Go down  Message [Page 6 of 7]
126And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 11th October 2016, 8:25 am
Yay! Another one "on the road" almost hehehe  Very Happy
Been a long time in build mode Rob, well done.
127And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 11th October 2016, 8:14 pm
If I'm honest it won't be on the road till the spring .
Not spent all this time getting it clean to ruin it driving on salted roads
128And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 13th October 2016, 9:16 am
Ordered a few new bits from nissan
4 x hub to shock bolts + nuts
4 x anti roll bar bolts
6 x upper shock nuts
1 x clutch fork dust cover
Off to get some more stainless bolts and nuts for things like abs wiring into inner arch
129And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 13th October 2016, 10:45 pm
Bear with me . This is the first time I've used the forum uploader for photos. .
Usually use photo bucket
[url=https://servimg.com/view/17951910/11]And it begins.  Robs big pulsar rebuild - Page 6 20161010[/url
Drivers side suspension looking better .
Waiting for new nuts and bolts from nissan
130And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 12th November 2016, 8:57 am
Well yesterday this happenedAnd it begins.  Robs big pulsar rebuild - Page 6 20161110
Went for its mot ..
Straight through with no advisories
131And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 12th November 2016, 10:20 am
Ready for summer hope to catch up at a few meets next year mate
132And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 12th November 2016, 11:04 am
glad it got through with no problems
133And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 12th November 2016, 4:48 pm
The only problem I appear to be having is the front suspension seems to be locked out . Look how high the front is compared to the back .
It has GAB rally shocks that are non adjustable.
The front is absolutely solid I'm not a little bloke and I can bounce on the front and the suspension doesn't move a all .
Going to take it to bits next week and work out why it appears seized
134And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 12th November 2016, 7:27 pm
Is it new as in new secondhand or is it yours originally ? Could be the wrong springs on struts ?
135And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 12th November 2016, 9:23 pm
Mine originally . Been on it for 4 years ..
With standard springs .
But I think they've seized
136And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 12th November 2016, 9:31 pm
The springs set the ride height the shocks just dampen i dont see how they can be locked out so to speak .... but you should have so movement on standard springs ... i guess all you can do is take the springs off and see what play the shocks have when compressed ...
137And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 12th November 2016, 9:50 pm
Suspension has had no weight on it for two years
138And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 13th November 2016, 9:26 am
joetheeskimo
joetheeskimo
@ROB_IOW wrote:And it begins.  Robs big pulsar rebuild - Page 6 20161110
Front bumper vents look great. Any more exterior pictures.
139And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 13th November 2016, 9:32 am
Springs on upside down after painting ?
140And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 13th November 2016, 9:37 am
I didn't take the springs off.
Literally took the suspension off the car 2 years ago .
Sanded and painted the shocks and then put it back on.
Not striped any part of the suspension down .
That's what makes me think it's seized . Coz with it not fitted to a motor and no weight onit it's been fully open for 2 years
141And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 13th November 2016, 11:18 am
possibly valve issue in the strut damper and once extended oil restriction stopping compression.
they old so corrosion etc all possible. easy see what wrong once spring and boot off .
even if dead gab bodies worth keeping as 50mm tubes are best for inserts such as bilsteins .
142And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 14th November 2016, 3:35 pm
Well I striped the front suspension down today .
The struts do move up and down but bloody he'll it takes some effort ..
I think they are just really really solid suspension .
Maybe I've just forgotten how hard it was .
I've ordered some standard shocks to go on the car because I can't drive it with it being this stiff
143And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 15th November 2016, 10:23 am
@ROB_IOW wrote:I can't drive it with it being this stiff
may i suggest
sheep shag yoursofunny
144And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 16th April 2017, 11:31 pm
Realised I don't have a fished picture of the engine bay ..
So here she is in all her glory ☺ ☺ ☺
And it begins.  Robs big pulsar rebuild - Page 6 20161211
145And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 17th April 2017, 4:24 am
Looks well clean mate
146And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 17th April 2017, 6:31 am
Nice please straighten radiator cap tho lol
147And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 17th April 2017, 4:27 pm
Very tidy engine bay Smile
148And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 17th April 2017, 10:05 pm
Took alot of work to get it looking like that.
Rad cap is now straight
149And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 26th April 2017, 8:05 pm
Few exterior pics
And it begins.  Robs big pulsar rebuild - Page 6 20170420
And it begins.  Robs big pulsar rebuild - Page 6 20161212
150And it begins.  Robs big pulsar rebuild - Page 6 Empty Re: And it begins. Robs big pulsar rebuild on 26th April 2017, 9:13 pm
I haven't said this for a while but... Rob this thing looks fucking awesome!
Back to top  Message [Page 6 of 7]
