Gtir Motorsport club » Tech room » Help and Advice » broken down :(
broken down :(
Go to page : 1, 2, 3  Next
1 broken down :( on 7th November 2014, 6:51 pm
Been having a few electrical issues lately and when i started my car at work today the battery light stayed on and my gauges actually started working again (they have not worked in about a year, anyway i broke down as my engine lost power and just cut out so i was running on battery power only for about 12miles, got jump leads and started it again but it just wore tge battery out, it sounded like the starter motor or altenator was making a horrible sound when the car was running (like a pulsing scraping). Is this my altenator dead or is there an earth which goes to tgis which could cause this issue, car has been sitting parked all day while ive been at work
Thanks in advance
Sye
2 Re: broken down :( on 7th November 2014, 8:03 pm
Sounds like the bearing in the alternator. check earths tho if things aint work
I mean as well as the alternator as that will be the problem. Put a multimeter acoss should get around 14.4v when charging
3 Re: broken down :( on 7th November 2014, 8:04 pm
There is the connector on the back of the alternater that can break away .... i would get the car running then chuck a tester on the battery you should see over 12.4 volts ideally around 13 to 14 volts if the alternater is throwing a charge back from what you was saying and the symptoms i would be leaning towards the alternater being fooked with the noise your describing ...
4 Re: broken down :( on 7th November 2014, 8:05 pm
Lol just beat me to it johnny i guess i need to type quicker Laughing
5 Re: broken down :( on 7th November 2014, 8:30 pm
Ha ha what can i say fingers were on the buttons txting. Its not a race tho (looser lol)
6 Re: broken down :( on 7th November 2014, 11:36 pm
Yup its the bearings in the alternator, aa came and there was bits of metal flying out of the alternator so thats what they said, gutted Sad
7 Re: broken down :( on 8th November 2014, 12:05 am
No fault would be better but at least its a cheap easy fix could of been alot worse and more expensive
8 Re: broken down :( on 8th November 2014, 11:11 am
As long as you don't have air con nice and straight forward
9 Re: broken down :( on 8th November 2014, 12:22 pm
Lol yeah ive got aircon, is it a pain to do with aircon in? Sad
10 Re: broken down :( on 8th November 2014, 1:45 pm
I ended up removing my air con when I replaced the alternator as i just couldn't get the bolt out with the pump in place. Others on here might know a way but everything I tired didn't work.
11 Re: broken down :( on 8th November 2014, 3:58 pm
yeah your gonna have to drop the ac pump unfortunately, then remove the alternator with the cast bracket attached then remove the pivot bolt when its off
make sure you disconnect the batt lead before working on it as you can blow the voltage stabilizer on the replacement unit if you plug the thing in with the battery connected ; )
12 Re: broken down :( on 8th November 2014, 5:16 pm
Is dropping the ac pump alot of work?, i want to try and do the job myself
13 Re: broken down :( on 8th November 2014, 5:23 pm
No just take your time and good on you for trying yourself. Are you keeping aircon after ?
14 Re: broken down :( on 8th November 2014, 5:37 pm
Yeah i may just keep the aircon in, doesnt really help performance removing it does it? Yeah i like doing this sort of stuff as it amazes me how much garages charge for anything to do with these cars
15 Re: broken down :( on 8th November 2014, 7:00 pm
Yes it uses abit and the whole set up is heavy but if you have no need dont remove it as so many do. Just was goin to say as you would need a different belt. Stick a new belt on with new alternator. Do you have a windy gun ? As you will prob need to fit your pully if its a recon/exchange unit
16 Re: broken down :( on 8th November 2014, 7:52 pm
Whats a windy gun? Wont be n exchange just getting one sent from bob
17 Re: broken down :( on 8th November 2014, 8:41 pm
Thats fine then. I crap with links google windy gun it basically a gun which vibrates and spins at same time to remove stuff like nuts and bolts. Ie on your alternator if you needed to swap pully it would just spin you would need a windy gun or a set of grips n socket set but trying to hold pully and slacken at same time is tricky or you could damage pully. All this is not important if bobs one has it on
18 Re: broken down :( on 8th November 2014, 9:21 pm
Do you mean an impact rachet/wrench ... ????
19 Re: broken down :( on 8th November 2014, 9:45 pm
An impact wrench (also known as an impactor, air wrench, air gun, rattle gun, torque gun, windy gun) is a socket wrench ...
20 Re: broken down :( on 8th November 2014, 9:47 pm
https://www.google.co.uk/search?q=windy+gun&client=safari&hl=en-gb&tbm=isch&tbo=u&source=univ&sa=X&ei=Go9eVL30C4qN7AarpYCoDg&ved=0CEoQ7Ak
21 Re: broken down :( on 8th November 2014, 10:09 pm
Thats the one ... never heard it called a windy gun before ...
22 Re: broken down :( on 8th November 2014, 10:12 pm
Well it is where real men live you southern poof lol
Impact sockets adaptors extensions
See we call it a air ratchet for well as it says ratchet for compressor as it dont vibrate its just air powered ratchet
23 Re: broken down :( on 8th November 2014, 10:22 pm
I just thought it shortend for all you thick northerners who struggle with words with more than two syllables Laughing
Even us sothern poofs know its as an air rachet Wink
24 Re: broken down :( on 8th November 2014, 10:31 pm
Ha ha could well be i am half asleep aint got a decent one back so i will let you have that one
25 Re: broken down :( on 9th November 2014, 12:46 am
Lol i won i won .... feels like ive really acheived something today now lmao ....
