Gtir Motorsport club » General Discusion » Gtir related Discussion » Whats the spline size on the gtir ?
Go to page : 1, 2, 3  Next
1Whats the spline size on the gtir ? Empty Whats the spline size on the gtir ? on 12th November 2014, 10:21 pm
mikewazowski
mikewazowski
Hi guys im going to be putting spacers on my R and i'll be putting longer wheel studs. Just wondering if anyone knows what is the spline size on the R? thanks!
2Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 12th November 2014, 10:57 pm
Thread size is M12x1.50
3Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 12th November 2014, 11:03 pm
I think he means spline not thread size. Spline is the oppersit end
4Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 12th November 2014, 11:07 pm
Diameter of spline is 14.3mm I'm pretty sure
5Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 12th November 2014, 11:43 pm
mikewazowski
mikewazowski
thread is 12x1.25, spline is the part that sits in the hub itself and secures the wheel stud
Whats the spline size on the gtir ? Colonnette-a-piantaggio-whi_1_2_2 in place.
6Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 12th November 2014, 11:46 pm
Oh my bad duh How thick spacers are you planning??
7Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 12th November 2014, 11:49 pm
mikewazowski
mikewazowski
I currently have a set of four 20mm ready to be fitted but i might go 30mm on the back and 15mm at the front. The 20mm all round will only be a temp thing Smile
8Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 13th November 2014, 12:40 am
gtirnick
a lot of ppl in north america use the arp wrx studs
i bought a set of these from these guys
http://www.sr20-forum.com/tdmimports-kuo-s-garage/63013-tdmimports-extend-wheel-studs.html
9Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 13th November 2014, 5:14 pm
Doesn't this kill wheel bearings?
10Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 13th November 2014, 5:39 pm
I've got friend who got porsche wheels on new beatle (don't ask why lol) and bearings are ok although her spacers bolt on to hub and wheel bolts to spacer to me that would be more solid fitment than extended studs I wold be worried that stud would snap
11Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 13th November 2014, 5:41 pm
http://www.ebay.com/itm/4-WHEEL-SPACERS-ADAPTERS-4x100-to-4x114-3-1-THICK-4-LUG-4x100-to-4x4-5-/271217862403
that sort of spacers I'm on about
https://bbmgarage.co.uk/
12Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 13th November 2014, 9:11 pm
mikewazowski
mikewazowski
ive got a set like that which bolts on to the hub first but id rather have extended studs then one bolting into another.
technically speaking there shouldnt be much weight on the studs because you have to use spigot rings for the weight to be supported by the hub not the studs. If i was just to put spacers on without putting any spigot rings then they could possibly snap. I guess theres only one way to check Very Happy
13Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 4th December 2014, 12:24 am
Juggs
Don't know how much, if any use this is but I recently brought a set of Greyston extended wheel studs, M12x1.25 with the 14.3 spline which they list for nissan & they 100% do not fit, the spline pitch is different to the stock ones so they won't seat in the hub correctly
14Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 4th December 2014, 12:17 pm
Spline is 14.3 on nissan.
Buy very high quality only & for nissan subaru fitment & chance of issues is minimal.
15Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 5th December 2014, 2:36 pm
mikewazowski
mikewazowski
I was thinking of going to m12x1.5 because i already have a set of really good wheel nuts in that size. 100% positive that its 14.3mm? Im about to order a full set and theres no returns haha Very Happy
16Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 5th December 2014, 3:01 pm
I used 14.3 myself with no issue.
It was short collar spline & flat shoulder as in image below.
Was subaru or nissan fitment, pressed in hub perfect.
Whats the spline size on the gtir ? 5sr0cln7dWhats the spline size on the gtir ? 14_3_spline_stud
17Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 5th December 2014, 3:02 pm
mikewazowski
mikewazowski
where did you get yours from? are they good quality?
18Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 5th December 2014, 3:15 pm
I got mine from Ratchada pitstop&race which a tuning & accessory parts store. used same studs on Subaru too & had no issues to date.
Mine had NEO packaging for brand.
Looked identical to Grayston style stud.
Grayston are uk based & a big supplier of specialist studs & I believe their stuff gets rebranded under quite a few labels.
Few motorsport shops use grayston so probably decent choice.
19Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 5th December 2014, 3:16 pm
throw a link up of what you considering ...
20Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 25th March 2017, 10:21 am
I bought these this week for 20mm rear spacers I'm fitting:
https://www.ebay.co.uk/itm/371021933053
But having a nightmare fitting them, there's more splines than standard studs. Ive tightened a nut up against a socket to pull the stud though but can't get the last 3mm through into hub.
I've machined a bit of the spline off as these ones are a few mm longer than standard ones, if I could get it all the way in I didn't want it fouling the disc, pushing it out etc
Whats the spline size on the gtir ? F9282E2A-6DFB-43FC-AB87-DA61B04C9A3B_zpsu7kyn7qo
As you can see it's mauling the splines trying to get it in  Mad
Gaz
21Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 25th March 2017, 10:45 am
That's no good, certainly seems some is off with them. Out of curiosity what were you using to tighten them up rattle gun or ratchet?
22Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 25th March 2017, 12:01 pm
Long extension bar mate, machining the splines to same as stock ones I managed to get them in
Whats the spline size on the gtir ? 8BBDC3AC-0D7E-42B2-B9F1-EB9BFBA9D996_zps2bopned2
Lowered car down moved it back and forwards to settle tyres, noticed wheel seems to kick out at top slightly, guessing moving wheel out 20mm I need to adjust the camber, boo. Whole car needs 4 wheel alignment anyway.
23Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 25th March 2017, 12:26 pm
That's good you got them to fit mate, just abit of mucking around.
24Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 25th March 2017, 12:43 pm
Lucky you got lathe, was it mainly spline length or also spline diameter a bit tight !
What was actual spline diameter before tweaking .
ones I used fitted as easy as oem, only real visual difference on mine was splines had a tiny machined taper at back so act as gap catch any fitting debris, does seem like some differ in dimensions or it a tolerance issue ! as recall few people having stud fitment issues over the years.
25Whats the spline size on the gtir ? Empty Re: Whats the spline size on the gtir ? on 25th March 2017, 8:58 pm
Mine were tight but went long socket and long nut so it did not strip it or stud and few hits from behind
