Gtir Motorsport club » General Discusion » Gtir related Discussion » Whats the spline size on the gtir ?
26Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 25th March 2017, 9:17 pm
I measured 14.3, but because the hub already has less grooves cut in from the original splines it was hard going pulling the new studs with extra splines in. Maybe if I'd used the impact gun it might have been quicker. The big difference was shaving 3mm off the splines less to pull through. Not sure if I'm going to use the spacers though after all this Laughing ended up buying Audi 20mm hubcentric spacers for £17 each, CB 57.1 popped them into lathe and bored out to 59.1 Cool got ally spigot rings to adapt from 57.1 to 72.6 wheel side. Not sure I like the fat ass look Laughing
27Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 26th March 2017, 9:13 am
Any pictures of it with wheels on spaced ?
28Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 26th March 2017, 11:52 am
I pulled the car out to take a pic especially for you Laughing
Whats the spline size on the gtir ? - Page 2 57BD7848-2849-438F-B63D-5E33483AFD93_zpscjyxpa0k
Haven't put the rear arch trim on yet so might look worse because of that
Whats the spline size on the gtir ? - Page 2 70343725-2586-4ED7-9311-B13F02BC488D_zpsw3qezzgg
Whats the spline size on the gtir ? - Page 2 69965E19-2F53-48CF-A06D-39242897491B_zpsxxd07b4v
If I do keep them, the camber definitely need adjusting
Whats the spline size on the gtir ? - Page 2 80E0FF7D-6ECE-4394-857C-403B318DB9D8_zpsjzrmlap3
Is that right with spacers, you need to adjust camber?
29Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 26th March 2017, 8:32 pm
I wouldn't have thought so? If nothing on the suspension has changed, all a spacer is doing is moving the wheel out. Spacer can change other characteristics but not camber I would have thought.
30Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 26th March 2017, 8:46 pm
That was my way of thinking as all you are doing is pushing the wheel further out ... not altering the hieght like lowering or owt .....
31Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 26th March 2017, 9:07 pm
Thanks and what is adjustable on your suspension ? Do you have camber bolts fitted ? Looks nice but well out of line mate
32Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 26th March 2017, 9:47 pm
I've got Bc coilovers and just standard bolts not camber ones. I am thinking possible bearing problem, had similar problem years ago when I clouted a curb in the snow, thought I'd done serious damage turned out bearing collapsed, doh. I'll take spacer off and see how it looks without, still same pop bearing out. All bearings were new when I rebuilt it but who knows!
33Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 26th March 2017, 10:03 pm
Is it like it both sides ?
34Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 27th March 2017, 7:16 am
I haven't done the other side yet, but can't say I've noticed it looking like the photo above, saying that the passenger side looked fine before fitting the spacer. I did higher the coilovers as far too low for my liking on standard wheels, plus couldn't get trolley jack under car Laughing if I've gone too high could this alter the camber? Ive only highered it an inch nothing major.
35Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 27th March 2017, 7:20 am
That will be it then, I'm sure adjusting height will affect your camber.
36Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 27th March 2017, 8:21 am
It currently looks like a Toyota hilux Laughing
Can you use camber bolts on the rears? Or are they only for front suspension.
37Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 27th March 2017, 8:47 am
Yes you can and works better as less stress on them on rear, I used subaru front camber bolts from scrap car as free and bigger and stronger over 12mm type for standard hole (Good 12mm ones fine on rear though really)
Have to mod the top hole for subaru ones though but that easy enough . about 0.75deg-neg not bad on rear for road and should look better and drive better than current setting. as load of new parts and rebuilt needs full alignment done really . due to R's less than amazing handling good setup and good struts can make huge gains in grip and stability and tyre wear lol .
Look bit like a hilux not a bad thing lol .
38Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 27th March 2017, 10:21 am
Will the camber bolts sort my rear wonky wheel out? Or is there too much positive camber on mine that they won't get back to spec?
39Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 27th March 2017, 3:00 pm
need measure current camber and also see what likely causing it be off, 1 camber bolt tends give about 1.25deg adjustment at best .
40Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 27th March 2017, 3:34 pm
If I get chance will measure it tonight, thanks
41Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 27th March 2017, 5:25 pm
Could be the picture mate but even lowered or high looks well out to me
42Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 27th March 2017, 9:10 pm
So I've made a new tool
Whats the spline size on the gtir ? - Page 2 5A85036D-D684-46E0-A7B9-48DAB76C9D9E_zpss150p2tz
Laughing
Anyway, it shows the wheel in question has 0.76389846 positive camber
Whats the spline size on the gtir ? - Page 2 81CBD2C1-C401-496B-9C21-130AF244F036_zpsjf9sdoqj
Whats the spline size on the gtir ? - Page 2 2E3E831C-79AC-4FDF-983B-59A6D87F3FE5_zpssrjqiler
OSR has 0.30557459 negative camber but hasn't got a spacer on
Whats the spline size on the gtir ? - Page 2 82F03129-7705-487F-A1C0-E61B6A8694FF_zps5zzrvj8l
Think I'm going to strip the dodgy side down at weekend make sure everything is right.
Calculation I use is:
Inverse Tan (distance plumb line/rim size measured)=degree
Tan -1 (5/375)=0.76389846
43Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 27th March 2017, 11:08 pm
I like your tool, very smart idea thumbsup
44Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 28th March 2017, 12:02 am
Nice template/tool.
That's how all wheel measurements and alignments were done before they had machines and lasers to do them.
I can remember working with an Uncle of mine who used to do wheel alignments like that. I wish I had all his templates now, they were magical items. He used to have boards that would allow you to do headlight directioning as well.
45Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 28th March 2017, 4:00 am
Haha that cool Mr Burrows, always love your tool solutions :-)
obviously something off throw it that far out, from standard setting it about 1.25deg out .
worth checking lateral links hub, strut and top hat. you can gain some by slop in top hat fitting and strut to hub, with BC strut got be curious how accurate jigged so worth comparing all OS to NS for measures .
camber bolts or adjustable top mounts handy for precise adjustment but suspension wants good check be sure nothing out of spec. Done a supra once with similar camber issue and was top hub mount bent just fractionally from curbing impact probably, not visible by eye looking at hub but rule spotted it .
46Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 28th March 2017, 8:59 am
Id like to do the whole things myself, this was an interesting read for some ideas for the diy people
http://ls1tech.com/forums/suspension-brakes/1565421-diy-poor-mans-wheel-alignment.html
47Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 28th March 2017, 9:33 am
Quite a few interesting ideas on the interwebs, regarding diy wheel alignment. Got the camber idea from a mustang forum. The guy that made his had all the increments in degree's, I couldn't be bothered trying to work that out, so went for mm and a basic trigonometry sum.
I'm interested to see what I've built wrong, hopefully just a blob of paint under strut mount throwing it off?
48Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 29th March 2017, 7:45 pm
Good grief Mad  im just glad im not in slapping distance of you lot!  so I found the problem tonight.....
turns out theres camber adjustment on BC struts Laughing
Whats the spline size on the gtir ? - Page 2 EFDCB885-44A7-456B-A694-AAF26DFDCEDA_zpsigqc1zg9
As you can see i had it hard over to the left, pushed the hub over other side and cured the problem Rolling Eyes
randomly the spacer now looks right as well
Whats the spline size on the gtir ? - Page 2 548B0DDC-0493-4589-B1A9-3B6EE06FBE68_zps6nkgu70b
Still needs adjusting a bit more, running very slight positive camber still, but at least Im on the right path now.
Gaz
49Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 29th March 2017, 8:49 pm
That looks loads better .... so did you get the camber bolts with the coilovers ?
50Whats the spline size on the gtir ? - Page 2 Empty Re: Whats the spline size on the gtir ? on 29th March 2017, 8:55 pm
No the top hole on the strut is elongated so can move either direction a few mm. I just pushed the hub as far back as I could then tightened standard bolt, it did slip back a little hence the very slight positive camber now. I have ordered some camber bolts so might be easier to get it bang on.
