Gtir Motorsport club » Tech room » Help and Advice » enhancing time
enhancing time
1 enhancing time on 1st December 2014, 9:12 am
TomeiR
what does it mean to have the timing enhanced on the engine,
so the engine works harder taking stain off the turbo. i have a ecu mapped by blitz that does this. what are the dangers?
might sound dumb. any advise would be appricated
2 Re: enhancing time on 1st December 2014, 1:36 pm
Im not sure what that means cant really find to much on the net either .... maybe it means like it has more finer setting capabilities or something ???
3 Re: enhancing time on 1st December 2014, 2:07 pm
TomeiR
could be a tuning term. im intregiued..
4 Re: enhancing time on 1st December 2014, 2:19 pm
that ecu is un-programmable and timing is already advanced to the max on it for optimum performance with stock items fitted from japland
blitz, mines and a few others are pretty much all the same, all you can really enhance is your base timing manually to back it off and make the car a little safer on boost if you know what I mean
5 Re: enhancing time on 1st December 2014, 2:44 pm
TomeiR
that makes sense. i was told that the only people that could re-map would be biltz
so overall its a upgrate on the response of the engine
6 Re: enhancing time on 1st December 2014, 6:20 pm
yeah they have quite an aggressive mid range with a lot of ignition advance which is fine if the fuelling is all ok and everythings in tip top order.
always worth getting the fuelling checked on the dyno and making sure its safe at whatever boost your running at, if not then can back off base timing and solve any issues or bring boost down to a safe level
