Gtir Motorsport club » Tech room » Help and Advice » Z32 Maf set up
Z32 Maf set up
1 Z32 Maf set up on 8th December 2014, 7:06 pm
taylorrail
Hi i need a bit of advise on my maf set up, i would like to fabricate a 3" aluminium intake but am unsure of the best lay out for this. as i have the standard S bend at present which has the large and medium pipes capped off but also has the small pipe going to the solenoid with 2 more pipes capped off .now would i need to fit the small pipe with solenoid back into the new 3" pipe work? also should i solder wires to maf connectors ? any help much appreciated.
http://Taylorweldingfabrications.co.uk
2 Re: Z32 Maf set up on 8th December 2014, 7:12 pm
Most people end up heading to just behind the headlight ... keep away from too many bends are you running standard boost then ?
3 Re: Z32 Maf set up on 8th December 2014, 7:23 pm
taylorrail
Ok thanks heres list of spec so far
gt2871r
hks evc 5
fmic
400hp clutch
4 pot brakes
walbro pump
and i have z32 maf & 660cc injectors that i would like to take with me and fit b4 map
4 Re: Z32 Maf set up on 8th December 2014, 8:14 pm
5 Re: Z32 Maf set up on 8th December 2014, 8:16 pm
taylorrail
Cheers
