Gtir Motorsport club » Tech room » Help and Advice » Rear engine mount/stabiliser
1 Rear engine mount/stabiliser on 16th December 2014, 4:57 pm
mikewazowski
Hey guys, has anybody got any pics of where the rear engine stabilizer mount should be located? I've just Installed my front one which i filled up with poly and i was also thinking about doing the rear but i cannot find it, i spotted a bracket that looks like its off the mount which is located on the firewall? is that the one? thanks!
2 Re: Rear engine mount/stabiliser on 16th December 2014, 5:24 pm
Have you still got the Y bracket fitted for the top mount intercooler? As that may be in the way...
If you look down past righthand side of the inlet, then you will see the top of the gearbox, towards the back asif you looking where gearbox meets transfer box then you will see the mount on the top of the gearbox
3 Re: Rear engine mount/stabiliser on 16th December 2014, 5:35 pm
mikewazowski
I think that we're on about the exactly the same spot, but my R hasnt got a stabilizer there. I can see where it would mount on the firewall but theres nowhere to mount it on the box. I know that my R had the gearbox replaced at one point and possibly they just didnt put one on ;/
4 Re: Rear engine mount/stabiliser on 16th December 2014, 7:57 pm
It has a bracket bolted onto the gearbox that the stabaliser bolts to... So unless the bracket is missing?
5 Re: Rear engine mount/stabiliser on 16th December 2014, 8:07 pm
yeah bracket with a long pin on it, pin has a square edge so you can tighten the nut without it spinning Smile
6 Re: Rear engine mount/stabiliser on 16th December 2014, 8:13 pm
mikewazowski
yeah i think mine is missing by the looks of it ;/ doesnt the front stabilizer fit the back too?
7 Re: Rear engine mount/stabiliser on 16th December 2014, 8:57 pm
Yes i think there similar i would get one on for obv reasons
8 Re: Rear engine mount/stabiliser on 16th December 2014, 9:12 pm
mikewazowski
im just in need of the bracket atm ;/ my engine shakes really badly when i turn the car off and i thought that its the front stabilizer, i got one off bob, filled it up with poly. Put it on the car today but pretty much same thing happened so i started searching for the second one thinking its completely focked like the front was but as it turns out i havent got one haha Very Happy
9 Re: Rear engine mount/stabiliser on 16th December 2014, 9:43 pm
Gtirchris
Have a look at the other 3 mounts fella to make sure that they are not splitting, as if the stabilisers are in poor condition and/ or missing as your back one is it will have put more strain on these, iirc my engine started shaking on shut down and it turned out to be the main mounting on the drivers side. Smile
10 Re: Rear engine mount/stabiliser on 16th December 2014, 10:50 pm
mikewazowski
they'll have to stay as they are for now. Im planning on going poly sometime next year Smile I defo have to do the back and then see if the problem goes away
11 Re: Rear engine mount/stabiliser on 18th December 2014, 10:35 pm
gtirnick
u can stuff a energy suspension poly bush into the front stabilizer to stiffen it up
maybe it'll help offset the missing stabilizer
*** EDIT NM, im a dummy and can't read, you've already filled with poly
part number: energy suspension 7.1105g
i have nismo stabilizers and i pulled out the soft squishy rubber bushings and put in poly , have had them for a few years without issue.
just the es poly bushes need to be ground down a little bit on the sides as they're oval.
Last edited by gtirnick on 18th December 2014, 11:00 pm; edited 1 time in total (Reason for editing : im a dummy and can't read, you've already filled with poly)
12 Re: Rear engine mount/stabiliser on 18th December 2014, 11:16 pm
The big triangular bracket should be mounted to the transfer box and the stabiliser mount comes off that.
Front is normally a thinner motel holder and the rear holder is made of heavy gauge plastic and is thicker but they are both interchangeable.
You don't need anything more than filling the voids with silicone that is more than adequate without causing any vibration issues
                                GTI-R-US.CO.UK
                                            'In association with'
                                          'Services provided'
13 Re: Rear engine mount/stabiliser on 18th December 2014, 11:26 pm
mikewazowski
thanks for the advice guys Smile
Thats what i did with the front one i got of you couple of weeks ago bob, i had a tub of Poly thats used to seal bus windows etc which did the job perfectly but i still had the rattle, vibration and shaking when turning the engine off so investigated further to find out im missing the rear stabiliser and the stabiliser bracket.
have you got any of these brackets in stock by any chance? Wink
14 Re: Rear engine mount/stabiliser on 19th December 2014, 12:14 am
15 Re: Rear engine mount/stabiliser on 19th December 2014, 12:44 am
mikewazowski
thats the one Smile
16 Re: Rear engine mount/stabiliser on 19th December 2014, 1:37 am
Yeah sure il have one kicking about plus another stabiliser too if you need one
                                GTI-R-US.CO.UK
                                          'Services provided'
17 Re: Rear engine mount/stabiliser on 19th December 2014, 1:56 am
mikewazowski
if the one of the front fits and is okay to use then im fine but if its really necessary to have the one off the back on there then ill need one. How much for the bracket and mount Bob? Wink
18 Re: Rear engine mount/stabiliser on 20th December 2014, 3:59 pm
gtirnick
pic of my mount
part # energy suspension 7.1105g From Sentra/NX or Prothane 14-503 Sentra
no excessive vibration, holds the engine extremely well without any of the vibration of stiffening up the other mounts
have had this on my car since 2009
19 Re: Rear engine mount/stabiliser on 20th December 2014, 4:04 pm
Is that just the front part of the mount ? Or the rear circle part aswell
20 Re: Rear engine mount/stabiliser on 20th December 2014, 5:28 pm
gtirnick
should include both, but the smaller circle one isnt required kuz its already solid, unless u press it out for poly
http://www.amazon.ca/Prothane-14-503-Engine-Torque-Insert/dp/B002P8W6PM
http://www.amazon.ca/Energy-Suspension-7-1105G-Insert-Nissan/dp/B000CNB33S
the above are just links to what they look like, you can find them for like half that price if you search around
the energy suspension ones have little window cutouts i guess for vibration, i have the prothane ones which are solid. i have no vibration passed back into the chassis
21 Re: Rear engine mount/stabiliser on 20th December 2014, 5:36 pm
Any numbers for the full kit i see you have done the other mounts aswell
22 Re: Rear engine mount/stabiliser on 20th December 2014, 5:50 pm
gtirnick
probably cheaper to just get your local powerflex engine mounts..
http://www.sr20-forum.com/suspension-brakes-tech/14833-how-prothane-motor-mounts.html
