Gtir Motorsport club » Gallery » Members gti-r's » My ivory white R from trini
1My ivory white R from trini Empty My ivory white R from trini on 2nd January 2015, 1:45 pm
JapMc5141
This is my R bone stock and untouched at the moment, have her about 6 months now came with a slight engine knock so I decided to take the engine out for a rebuild but will soon be going under mods in the process my plans for her are as follows:-
Engine mods
Sr20ve head swap
Sr20vet pistons
Sr20ve oil pump
700cc injectors
Z32 maf
Aem water/meth injection
FMIC kit
GT2860rs .86 backend
Port and polished oem exhaust manifold
3" j pipe
38mm tial external waste
Tial dump valve
Greddy oil filter relocater kit
Aftermarket Catch can
SPEC stage 2+ clutch kit
Electronics
Greddy profec b boost controller
Nistune ecu
Auto Meter gauges oil pressure/boost/water temp/egt
Innovate wide band
Greddy turbo timer
Suspension and Brake Mods
BC racing coilovers
Cuzco strut tower braces
Poly bushings
Avenir GT double pot 11.4" brakes
Steel braided brake lines
Not sure about my choice of wheels as yet but I'll be going 16" something jdm
2My ivory white R from trini Empty Re: My ivory white R from trini on 2nd January 2015, 2:08 pm
JapMc5141
Will get pics up soon guys getting difficulty uploading them
3My ivory white R from trini Empty Re: My ivory white R from trini on 11th January 2015, 11:01 am
Juggs
Sounds like a good spec that mate, should spool that gt28 up nice & fast!
I've got an Ivory one as well, i bet its a pretty rare colour in Trinidad right?
4My ivory white R from trini Empty Re: My ivory white R from trini on 11th January 2015, 11:10 am
JapMc5141
Yes it is a rare colour in Trinidad buddy,only have about 2 or 3 ivory white on the island
5My ivory white R from trini Empty Re: My ivory white R from trini on 11th January 2015, 4:09 pm
ivory is a rare colour everywhere Wink
6My ivory white R from trini Empty Re: My ivory white R from trini on 17th August 2015, 3:14 pm
JapMc5141
Well my project is almost completed guys,sorry I can't get the pics uploaded for some reason
Few changes have been made from my original list above but the car is insane right now on just 7 psi
Those who are on the Facebook groups would have seen pics of the progress
So at present
SR20VE head
Avenir w11 block
Sr20VE oil pump
ARP rod bolts and Head studs
OEM exhaust manifold ported for wastegate
Tial type Q BOV
Tial MV-R 44mm wastegate
Garrett GT3071R turbo
AEM EMS 4 Standalone ecu
520cc side feed injectors
Oem coil packs
Apexi boost control solenoid
AutoMeter oil pressure/boost/water temp gauges
Innovate wideband
3" catback 5zigen
ACT XTSS clutch kit
APEX coilovers
7My ivory white R from trini Empty Re: My ivory white R from trini on 17th August 2015, 3:22 pm
I personaly would be worried about the arp head bolts.
Sounds a good spec apart from that.
What host are you using for your pictures? Most people use photobucket.com
8My ivory white R from trini Empty Re: My ivory white R from trini on 17th August 2015, 5:52 pm
Beat me to it stu .... i was going to say about the headbolts .... sounds awesome build so whats different between the avenir w11 block they are both sr20dets ...
9My ivory white R from trini Empty Re: My ivory white R from trini on 17th August 2015, 8:02 pm
gtir_pimp
gtir_pimp
Put the standard head bolts back in quick before the head lifts
Nice spec though
10My ivory white R from trini Empty Re: My ivory white R from trini on 17th August 2015, 8:03 pm
Good work with the VE head, share the results when it runs
11My ivory white R from trini Empty Re: My ivory white R from trini on 18th August 2015, 7:11 am
Dose he need to maybe they work on his different block ? Is it your post count stopping pictures ? Great progress I don't use face book and would like to see pictures of you can load them on here
12My ivory white R from trini Empty Re: My ivory white R from trini on 18th August 2015, 11:35 am
Maybe they are different but arp headbolts doesnt have such a good rep with the sr20det ....
