Gtir Motorsport club » Tech room » Help and Advice » blackjack n tubby timer
1 blackjack n tubby timer on 9th January 2015, 5:04 pm
TomeiR
can a clifford blackjack 650 run with a turbo timer?
2 Re: blackjack n tubby timer on 9th January 2015, 6:52 pm
Clifford Concept 650, with intellistart, boot release and turbo timer intergrated think from what i read they are extras but part of the alarm if that makes sense ... Smile
3 Re: blackjack n tubby timer on 9th January 2015, 6:57 pm
TomeiR
ive got the black jack seperate and a cobra ca1. hks turbo timer. while the turbo timer counts down as soon as you open the door the black jack arms
4 Re: blackjack n tubby timer on 9th January 2015, 7:04 pm
I have no idea with alarms mate i just read you can use a clifford intergrated turbo timer ... so it should have the function ....maybe worth emailing clifford see what they say ...
5 Re: blackjack n tubby timer on 9th January 2015, 11:52 pm
Yes clifford can be wired/set to run basic turbo timer without need for separate hardware. although turbo timers are pretty much pointless on water cooled turbos & quality synthetic oils ...
6 Re: blackjack n tubby timer on 12th January 2015, 9:28 am
TomeiR
thats really good news. i think the black jack is a really good bit of kit.
so i will need a good sparky to wire this in.
7 Re: blackjack n tubby timer on 12th January 2015, 9:56 pm
mightydquinn
I've got black jack on mine, full closure, proximity sensors and the bit that you will like, remote start and stop! So I can leave it running for as long as I like from when I get out, press the button and then it just turns itself off! Smile it's also really good for starting it up before you get in it so it can warm up nicely by itself before in ready to drive off in it! Smile Get that pal, you'll love it!
8 Re: blackjack n tubby timer on 15th January 2015, 3:22 pm
TomeiR
thing is. i got the black jack. got the cat one. wired in the tubby timer. i can get just the remote start module.. cheaper
but again i dont know wheather i should jus rip it all out and put a 650 in
