Gtir Motorsport club » active members adverts » Parts Wanted » Blueprint outer cv boot
1Blueprint outer cv boot  Empty Blueprint outer cv boot on 11th January 2015, 2:38 pm
ga3
Could anyone advise me as to where I can get a cheap outer cv boot from please? The one euros had sold me was too small and have already cut the old one off as well doh!
Thanks
2Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 11th January 2015, 3:02 pm
eBay?
3Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 11th January 2015, 3:47 pm
it actually fits as i bought one and seemed too small, managed to get it on eventually
4Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 11th January 2015, 3:48 pm
but ebay for the cv joint and boot, the kit costs about the same as just a boot and its a much better fit than the europart
5Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 11th January 2015, 4:02 pm
ga3
Thanks digitalfaze and shroom I will have a go at fitting it tbh I didn't try I had just finished the o/s inner boot had stripped n/s to do the outer had a look at it and thought it looked too small will definetly give it a go though if not probably do eBay took 3 weeks for the inner one from nissan don't want to wait that long again lol
6Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 11th January 2015, 4:15 pm
yeah you need to stretch it to fit over, bit of a pita but it will go on, best using cable ties as the clips supplied wont stretch around it because the boot is stretched, i was in the same position really, done the other n/s boots with the ebay ones then went to do the o/s outer with a europart (think it says on the box mazda and some other make, not nissan :/ ) took the boot off and cried and moaned at the missus for ordering stupid parts but thought i had better try it as everything was off, its a really tight fit and i intend to fit a better one later on when i have time
7Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 11th January 2015, 4:16 pm
yeah the cv joint and boot kit from ebay for like £18 is ok, i never used the joint just the boot but its a perfect fit
8Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 11th January 2015, 5:01 pm
Yeah its not a very pleasant job at the best of times. I had a quick look on eBay before posting and there was some reasonable stuff on there. I have always got them from there. Hope you get it sorted :-)
9Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 15th January 2015, 1:33 am
done a thread just other day in useful links on this
Outer is same as gti almera primera & can be found at any decent motorfactors.
ICP stock all front & rear except front LH tripiod one which needs be blueprint & is about £14
All other are £7ish or less.
The ICP boots are very very good quality >
http://www.gtir-motorsport-club.com/t4373-cv-boots
10Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 15th January 2015, 1:35 am
@Mr B wrote:done a thread just other day in useful links on this
That's usefull as I need to do my drivers side inner boot when I change my box Smile
11Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 15th January 2015, 1:40 am
£6.55p
http://www.importcarparts.co.uk/parts_info.asp?id=8376&cat=87&sub=119&sec=0&var=0&dc=&gen=&searchKey=&searchPart=
or ADN18119 from your local motor-factors ...
12Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 15th January 2015, 1:53 am
Brilliant, cheers matey Smile
13Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 15th January 2015, 2:51 am
Whytie
Whytie
I always fit the universal ones, cost peanuts and fit good
14Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 15th January 2015, 4:19 am
proper ones fit better & bellowed better to the joint & also peanuts price if shop about or get trade at a motorfactors.
eBay not the cheapest & tends to be 30%+ on prices for basic parts like this .
15Blueprint outer cv boot  Empty Re: Blueprint outer cv boot on 15th January 2015, 5:15 am
first line parts do the outers
PART NUMBER: FCB 2062
BRAND: First Line
PRICE: £4.90
also do front right inner
PART NUMBER: FCB 6031
Solid Ace parts do them too but quality to price the ICP boots are best followed by Blueprint if factors do you trade.
