Gtir Motorsport club » Tech room » Help and Advice » Abs problem
Abs problem
1 Abs problem on 18th January 2015, 7:55 am
Well my abs ecu was saying the near side sensor was faulty, anyway I've changed that and checked and cleaned the abs ring on the hub but still showing a fault. Any idea's. As it's not taxed I can't take it a good run as maybe there was a second fault after the bs sensor. Hmmmm might be worth a sneaky ride out
2 Re: Abs problem on 18th January 2015, 8:39 am
Yes ideally it needs to be driven a few miles then recheck abs ecu led for codes of perhaps second fault.
What is the status of the dash warning light, is it staying on or going off after initial ign on self test mode.
3 Re: Abs problem on 18th January 2015, 9:21 am
Start car up and it goes off on tickover, as soon as you get to about 5 mph it comes on and stays on
4 Re: Abs problem on 18th January 2015, 9:34 am
Actual driving or on stands & in gear !
5 Re: Abs problem on 18th January 2015, 9:48 am
All problems I've had with ABS is broken wires to the front sensors where it flexes round the suspension leg.
The fault light won't come on until the car's moving. If it doesn't get a signal from all 4 wheels then it puts up the fault light.
The fault codes will tell you which sensor.
http://www.gtir-motorsport-club.com/t82-abs-fault-check
6 Re: Abs problem on 18th January 2015, 3:18 pm
Done fault code and it said front N/S so changed and checked wires already but still showing fault. Tried it driving down drive and light is still coming on but until I get it on the road I won't be able to check if now it's throwing up a different code
