Gtir Motorsport club » Tech room » Help and Advice » New rear brake discs
1 New rear brake discs on 21st January 2015, 4:52 pm
paz
What are peoples recommendations on the best discs for the rear of the pulsar and where to buy them?
Looked for oversized kits but they're extortionate considering they retain the standard caliper.
Cheers
Paz
2 rear discs on 21st January 2015, 8:18 pm
hi. im the same as you, need new rear discs i have standard calipers so going to fit adn14376
3 Re: New rear brake discs on 21st January 2015, 8:36 pm
gtirnick
1995 maxima 5x114 rear 278mm /aka 10.94" rotor redrilled
RAYBESTOS Part # 96511
or 2004 spec V brembo rear redrilled same rotor size except 4x114 , slightly safer on the redrill pattern
CENTRIC Part # 12842082R
CENTRIC Part # 12842082L
RAYBESTOS Part # 980308
CENTRIC Part # 12042082
30-100$ per rotor(large variation due to if you buy slotted/powerslot, branded ,jobberetc) plus cost of redrilling
maxima rear caliper brackets, spaces the oem caliper back to the centerline of the car 12mm and further out out 10mm for the 20mm larger disk 40-80$ for caliper brackets
A-1 CARDONE Part # 141506 DORMAN Part # 619503
you can reuse the oem caliper, or get a rebuilt g20
remove, trim, or bend the heatshield out of the way
4 Re: New rear brake discs on 21st January 2015, 9:39 pm
mikewazowski
ive heard some good reviews off a bloke who used to do hill climb in his pulsar about bigger discs with stock calipers on the back so defo worth a shot!
5 Re: New rear brake discs on 21st January 2015, 10:03 pm
gtirnick
80 percent of the braking is done up front, i wouldn't be too concerned about a larger rear caliper unless you're looking for a hydraulic steering brake
i'd look at not using a shitty tire and shitty brake pad before changing calipers.
6 Re: New rear brake discs on 21st January 2015, 10:04 pm
Isnt there the like the hispec kit wich uses bigger discs with stock caliper but moves it up on a bracket ...
7 Re: New rear brake discs on 21st January 2015, 10:14 pm
gtirnicks tip on the 278mm discs is a good one but you might have bit of trouble sourcing brackets for caliper in UK.
Other options are Black Diamond or ICP standard discs
http://www.importcarparts.co.uk/parts_info.asp?id=1426&cat=87&sub=119&sec=1184&var=27&dc=0&gen=&searchKey=&searchPart=
8 Re: New rear brake discs on 21st January 2015, 10:20 pm
@nomad wrote:Isnt there the like the hispec kit wich uses bigger discs with stock caliper but moves it  up on a bracket ...
Hispec do 2 kits I think with the 300mm one being bit pricey & 280 kit being pretty much same as gtirnicks maxima conversion.
Godspeed done one too.
All sell quickly used & don't come up often ...
9 Re: New rear brake discs on 21st January 2015, 11:09 pm
Thanks mr b .... i thought i remembered reading it somewhere there was a kit availible ....
