Gtir Motorsport club » Tech room » Help and Advice » What oil..??
What oil..??
1 What oil..?? on 26th January 2015, 12:20 pm
Chrism
Standard road car..??? What do people recommend
And any good valve and tappet treatment.??
2 Re: What oil..?? on 26th January 2015, 1:04 pm
http://www.gtir-motorsport-club.com/t87-gtir-engine-oil
0 40w ..... 0 40w  i wouldnt go much higher like a 50 if your only using it as a road car ....
3 Re: What oil..?? on 26th January 2015, 1:43 pm
most use 10w/50 fully synthetic but for road use 10w/40 will be fine
as for all the oil enhancers...........all a waste of money
however ive used fortay fuel injection additive before and that's very good and keeps injectors / valves ect clean but if you use good quality fuel then most fuels now already have a lot of these additives when produced so even that's a waste of money really nowadays
4 Re: What oil..?? on 26th January 2015, 2:09 pm
i use 10w50 fuchs in my daily since ive owned it, expensive but seems good stuff
5 Re: What oil..?? on 26th January 2015, 5:23 pm
grim_d
10w50 fuchs titan race for me too.
6 Re: What oil..?? on 26th January 2015, 9:13 pm
gtir_pimp
Am I the only one that uses 10 60? Or used to when I had the car
7 Re: What oil..?? on 26th January 2015, 10:30 pm
Wasnt 10 60 old skool what people used to use back in the day? 10 50 seems the norm now
8 Re: What oil..?? on 26th January 2015, 10:41 pm
5 30 semi from Wilco. The old beemer's done 150,000 miles on it now and still doesn't use any between changes... Smile
9 Re: What oil..?? on 26th January 2015, 11:52 pm
I would of thought 60 is abit thick ....
10 Re: What oil..?? on 27th January 2015, 12:00 am
No 10 60 is fine especially for hard use in the summer when ambient temps are high. the 60 indicates the oils viscosity when hot so basically gives the same protection as say a 10 40 when cold but when at optimum temp it provides that bit more protection which is ideal for a track car and any vehicle that's really put through its paces
11 Re: What oil..?? on 27th January 2015, 12:03 am
Oh right cheers bob i thought it was a thicker oil scratch i knew it was more of a choice for track orientated car ...
12 oil on 27th January 2015, 4:44 pm
hi, i have always used castrol magnatec 10 40w part synthetic never had any issues... mine is standard. fully synthetic and 0 to 50w in my opinion is track stuff.
13 Re: What oil..?? on 27th January 2015, 9:31 pm
I use 10/40 and a oil cooler and works well from cold start up to very spirited driving on the road i could not get 10/50 up to optimum working temps on my stack gauge. Red hot summer days 10/50 is what i use but 10/40 is still ok. Track go as said 10/50 or 60
14 Re: What oil..?? on 27th January 2015, 9:57 pm
grim_d
Johnny what brand do you us? been considering switching to 10w40 but fuchs don't seem to do the titan race in it.
15 Re: What oil..?? on 27th January 2015, 10:11 pm
Thats the make i use mate. I did buy a few last time so ain't bought it but they were also doing 5/40 which i feel its not needed as its never that bad temperature wise but protects on cold starts which is never a bad thing
16 Re: What oil..?? on 27th January 2015, 10:22 pm
grim_d
They must have discontinued it. Millers cfs comes in 10w40 so might try that.
They do do titan in the 5w40 but im not sure about it.
Just filled up with 10w50 yesterday Mad
17 Re: What oil..?? on 28th January 2015, 3:38 am
Indy
10w50 Fuchs for me too
18 Re: What oil..?? on 28th January 2015, 7:04 am
That is it motul 300v (racing) in silver tins i think a lot of people use that (other performance and turbo cars) not sure what peoples thoughts are ?
I was once told that vauxhall 10/40 oil is produced in the same factory and is exactully the same as fucs Titan race without the fancy bottle the lad i know swears thats the truth and i could buy it off him in 6 x5l bottles at a time and save a fortune going halfers with someone else
19 Re: What oil..?? on 28th January 2015, 7:18 am
grim_d
Wow that motul stuff isn't cheap! I've ordered some millers cfs to try.
20 Re: What oil..?? on 28th January 2015, 8:19 am
In some senses as long as you monitor oil temps and the cheaper you think it is within reason do your oil change slightly early than normal. Glad your sorted
21 Re: What oil..?? on 28th January 2015, 8:32 am
grim_d
Like you I struggled to get the fuchs 10w50 up to temp, in fact I just couldn't manage it.
The millers isn't really cheaper than fuchs as it's an ester too, call me cheap but I'm certainly reluctant to pay nearly £14 a litre for the motul.
22 Re: What oil..?? on 28th January 2015, 8:49 am
@johnny gtir wrote:That is it motul 300v  (racing) in silver tins i think a lot of people use that (other performance and turbo  cars) not sure what peoples thoughts are ?
I was once told that vauxhall 10/40 oil is produced in the same factory and is exactly the same as fucs Titan race without the fancy bottle the lad i know swears thats the truth and i could buy it off him in 6 x5l bottles at a time and save a fortune going halfers with someone else
Fuchs did supply GM oil so is possible some of the top range vauxhall branded oils good. Doubt spec exact same as direct brand top products though.
