Gtir Motorsport club » Tech room » Help and Advice » fuel pipes (top of fuel tank)
1 fuel pipes (top of fuel tank) on 6th February 2015, 1:50 am
As above what does the middle pipe do? Seem to have a small slice in the pipe but only seems to drip a bit of fuel when the car is sitting, noticed a smell of fuel after car was parked, grrr wish the guy fixed all the pipes when it was done but only replaced 1 of them
2 Re: fuel pipes (top of fuel tank) on 6th February 2015, 3:06 am
GTIR James
Think the middle pipe is the return from the fuel rail.
3 Re: fuel pipes (top of fuel tank) on 6th February 2015, 3:15 am
Ah ok i was thinking it was something like that, is there anything i can do to patch it till i get some time to drop the subframe and replace it?
4 Re: fuel pipes (top of fuel tank) on 6th February 2015, 3:37 am
Where is the slice mate?
5 Re: fuel pipes (top of fuel tank) on 6th February 2015, 3:51 am
Its about where the nozzle which the pipe goes over ends, its not serious and im not sure there will enough pipe to cut it back a bit, about 5cm from end of hose
6 Re: fuel pipes (top of fuel tank) on 6th February 2015, 4:06 am
maybe cut it back enough to try get split on the metal fitting.
Other option could be a joiner perhaps !
Bit of a PITA that :-/
i done that with the fuel pipe which is connected to the pump when that one split, it wasnt hard but it didnt work and just caused horrible running issues, i guess if its just a return pipe there is no pressure going into it so it shouldnt really affect anything?
7 Re: fuel pipes (top of fuel tank) on 6th February 2015, 4:19 am
As B said ^
Or if it's bad leave the factory return line where it is and run another new piece of fuel line from the tank to the metal fuel line. That will at least get you by until you drop the subframe and do it properly.
8 Re: fuel pipes (top of fuel tank) on 10th February 2015, 12:02 am
cheers ill see if i have enough to snip it back, connector in the pipe wont affect anything because its just a return? i used a connector on the left pipe and it caused all sorts of running issues
9 Re: fuel pipes (top of fuel tank) on 10th February 2015, 1:05 am
I can't see a connector causing any issue if connector bore not too small & it fitted well.
Would prefer shortening line if possible but it maybe worth effort on top effort on a join if you not in situation of replacement or running temporary line like woody suggested .
10 Re: fuel pipes (top of fuel tank) on 10th February 2015, 1:11 am
sorry to jump this thread, but just out of curiosity what is the diameter of the fuel lines? just wondering as I was going to order some hose for my swirl pot
11 Re: fuel pipes (top of fuel tank) on 21st February 2015, 12:48 am
think they are 8mm, 6mm or 10mm, i cant remember i got mine from halfords quite a while ago
12 Re: fuel pipes (top of fuel tank) on 21st February 2015, 2:10 am
@gtir_woody wrote:As B said ^
This is how I did all 3 years ago, will do it properly now its coming off the road
