Gtir Motorsport club » Gallery » Projects » JoetheEskimos GTIR Build
Go down  Message [Page 2 of 6]
26JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 29th March 2015, 3:50 pm
joetheeskimo
joetheeskimo
So heres some rust i discovered today.
JoetheEskimos GTIR Build - Page 2 20150329_162103_resized
JoetheEskimos GTIR Build - Page 2 20150329_162114_resized
JoetheEskimos GTIR Build - Page 2 20150329_162134_resized
Anyone know how much this will cost to repair. Both rear arches are bubbling as well.
27JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 29th March 2015, 4:20 pm
Check link in the useful link section .... for repair panels .... the rest depends on if you do the work yourself or get a bodyshop to do it .....
28JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 29th March 2015, 9:07 pm
joetheeskimo
joetheeskimo
@nomad wrote:Check link  in the useful link section .... for repair panels .... the rest depends on if you do the work yourself or get  a bodyshop to do it .....
Both arches ordered. Got a local guy who quoted £60 per side. Or £100 if the inner sills need doing as well.
This doesn't include paint. Will red oxide them and get them professionally sprayed once I have an engine fitted.
29JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 29th March 2015, 10:12 pm
Nice one thats not a bad price ... hopefully hes a good welder so minimal amount
Filler work .... i would say from the pic the inner arch will need doing that side the piece where it meets the sill is a common place to go ....
30JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 29th March 2015, 10:29 pm
Where can you get inner arches from? Or would the guy doing the welding just use some sheet steel?
Thats not a bad price on the arches.
Im paying £100 for one rear arch and 2 patches in the sills.
But im having them painted too so thats an extra £150.
3 weeks back order on my panels tho.
31JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 30th March 2015, 6:22 am
Rear wall of inner arch could be repaired using cuts from the n14 mudguard panel probably.
Most will use sheet metal & form as required for lip of inner arch & sill ends etc as quite easy do as not a visible panel.
To do a worthy job on the arches is not that quick a job so anything too cheap that not mates rates or cash special could be a disaster in 18 months.
See those arch repair panels are under £21 from carz2 now :-O
32JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 5th April 2015, 6:12 pm
joetheeskimo
joetheeskimo
today i made a start ripping off all the front suspension components so i can underseal and refurb all components.
half way through ripping it all out. Nice surprise finding GAB shocks. Anyone know what i can paint to use to respary springs.
JoetheEskimos GTIR Build - Page 2 20150405_170524_resized
look at the mud build up in the arch. before and after pictures
JoetheEskimos GTIR Build - Page 2 20150405_162525_resized
JoetheEskimos GTIR Build - Page 2 20150405_162658_resized
As you can see from the pictures the tie rod arms need replacing as well as the bottom ball joints. Im going to poly bush the lower control arms.
JoetheEskimos GTIR Build - Page 2 IMG-20150405-WA0021_resized
And after all the components are off
JoetheEskimos GTIR Build - Page 2 IMG-20150405-WA0028_resized
JoetheEskimos GTIR Build - Page 2 IMG-20150405-WA0027_resized
JoetheEskimos GTIR Build - Page 2 IMG-20150405-WA0020_resized
I sprayed the fuel rail silver to tidy up the bay. Im going to replace all the injector orings as they are perished.
JoetheEskimos GTIR Build - Page 2 IMG-20150405-WA0024_resized
also set about cleaning up the inlet manifold.
I will upload more picutres tomorrow once i have undersealed. Over next few weeks i am to do the following
- Strip lower control arms
- Poly bush and fit new ball joints to LCA
- Paint LCA
- Paint Calipers
- Replace worn out slider pin seals
- Clean and respray shock absorbers
- Fit new Tie Rod arms
- Fit all front suspension components
33JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 10th April 2015, 6:34 pm
joetheeskimo
joetheeskimo
So little update
bought the following items
-injector seal kit
-Front lower control poly bushes
-New Drop Links
-New Ball Joints
. Refurbished the brakes and also got carried away so bought a complete Superpro poly bush kit for all the rear arms.
Before
JoetheEskimos GTIR Build - Page 2 20150406_150209_resized
After
JoetheEskimos GTIR Build - Page 2 20150407_173637_resized
JoetheEskimos GTIR Build - Page 2 20150407_173750_resized
Undersealed the front while i had all the arms off.
JoetheEskimos GTIR Build - Page 2 20150406_160139_resized
Went to nissan today to see how ripped off i could get, Got the seal on the gearbox where the gear selector arm is and also the turbo return rubber hose. Cost me £40.
34JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 10th April 2015, 7:21 pm
Brakes came up looking great thumbsup
35JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 11th April 2015, 7:57 am
Keep up the good work mate good to see the updates
36JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 11th April 2015, 10:24 am
Nissan seal number please
37JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 2nd May 2015, 6:53 pm
joetheeskimo
joetheeskimo
So a big thanks needs to go to Bob, Went down to GTI-R-US yesterday to collect my new engine (Used engine). Bob took the sump off and let me look at all of the bottom end to make sure i was happy with it before rebuilding it. Engines still in the back of the car but slowly bolting parts back on to it before i put it back into the car.
JoetheEskimos GTIR Build - Page 2 IMG-20150502-WA0009_resized
JoetheEskimos GTIR Build - Page 2 IMG-20150502-WA0007_resized
After collecting the engine yesterday i also got carried away and bought an FMIC off of bob as well. He believes it is a Forge Intercooler but cant find any markings so im taking his word for it. Looks like a good bit of kit though, stainless steel pipe work. Really nice. Decided to get spraying it today, i hat shinny intercoolers, black nice and subtle.
JoetheEskimos GTIR Build - Page 2 20150502_125310_resized
Tomorrow i will get it bolted into place.
As ive got a fair amount of time before the car will be back on the road going to refurb my rocker cover. I love the HKS rocker cover colour scheme so will be painting like this.
JoetheEskimos GTIR Build - Page 2 Hks-spark-plug-cover-oil-cap-and-custom-painted-sr20det-valve-cover
Still need to get my front lower control arms sandblasted so they can be powder coated before the poly bushes and new ball joints are fitted.
Another job i need to do is order up oils, collect parts from Nissan
38JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 2nd May 2015, 8:08 pm
That intercooler not a Forge one.
looks like tube & fin core, bit damaged at bottom, is it pressure tested.
39JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 2nd May 2015, 8:19 pm
joetheeskimo
joetheeskimo
@Mr B wrote:That intercooler not a Forge one.
Oh ok. Not pressure tested but I have faith in bob and he says it fine so should be ok.
40JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 2nd May 2015, 11:17 pm
Thought that was a forge one as pipes are almost central, deffo not an eBay jobbie
The bottom is bent up a bit but as joe says it's not been pressure tested but car it came from was holding 1.3 bar boost so I know it's fine, if not then there's a full money back guarantee Wink
Great to see your getting her sorted joe and il get the bits you need in the post on Tuesday if you send me your addy..........you can have them fella, just cover postage
41JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 3rd May 2015, 12:37 am
Nice update, good to hear it's coming together!
42JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 3rd May 2015, 6:04 am
Deffo not forge.
Forge pipes are far more central to end tanks & one on o/s is longer & angled slightly inwards, also 2 threaded fittings are on core bottom rail & they have a large embossed Forge logo with web address embossed underneath in smaller print on the cores flat plate.
Don't recognise that core, most had end cap pipes closer to bottom :-/
Fair bit of work ongoing, good luck with the build ...
43JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 3rd May 2015, 6:53 am
MartyMG
MartyMG
Good to see your progress! Its reminding me of all the jobs that will need doing on mine though!
44JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 3rd May 2015, 7:41 am
joetheeskimo
joetheeskimo
@GTI-R US wrote:Thought that was a forge one as pipes are almost central, deffo not an eBay jobbie
Spot on thanks bob. Just pm me the postage costs if you can and I will send the money straight across.
45JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 2nd June 2015, 6:21 pm
joetheeskimo
joetheeskimo
modified my standard headlights yesterday. I did the same mod on my old 200sx. ive never seen it done on a gtir before so thought i would do it.
Baked the headlights in the oven for 30 minutes at 60c to soften the adhesive then removed glass, painted the outside chrome areas black and used yellow glass paint for the inside reflective area.
Re-sealed using clear window sealent and re-fitted to the car.
JoetheEskimos GTIR Build - Page 2 20150531_114748_resized
JoetheEskimos GTIR Build - Page 2 20150601_165734_resized
JoetheEskimos GTIR Build - Page 2 20150601_175710_resized
JoetheEskimos GTIR Build - Page 2 20150602_172033_resized
JoetheEskimos GTIR Build - Page 2 20150602_172025_resized
JoetheEskimos GTIR Build - Page 2 IMG-20150602-WA0013
JoetheEskimos GTIR Build - Page 2 IMG-20150602-WA0015
JoetheEskimos GTIR Build - Page 2 IMG-20150602-WA0017
JoetheEskimos GTIR Build - Page 2 IMG-20150602-WA0019
46JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 2nd June 2015, 7:41 pm
Looks pretty mean with the yellow paint .... how legal is it ???
47JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 2nd June 2015, 8:57 pm
Surly it's similar to rears supposed to have some natural reflection on ?
How bright are they with chrome bits black ?
Regardless of the above I like the look and certainly different on a R
48JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 2nd June 2015, 9:20 pm
MartyMG
MartyMG
If these catch on there could be a sudden rush on standard side repeaters?!
49JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 2nd June 2015, 9:42 pm
We aren't even allowed to paint the rear brake lights here. The yellow looks cool though.
50JoetheEskimos GTIR Build - Page 2 Empty Re: JoetheEskimos GTIR Build on 3rd June 2015, 4:25 pm
joetheeskimo
joetheeskimo
Never had an issue with mot with my 200sx with similar headlights. Yes the light is not as bright but to be honest it's more than good enough even on a dark twisty b road
Back to top  Message [Page 2 of 6]
