Gtir Motorsport club » Gallery » Projects » Moley's rebuild
Moley's rebuild
Go down  Message [Page 3 of 6]
51Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 5th November 2015, 8:25 pm
@johnny gtir wrote:I would be dangerous if I had somewhere good like that to work
You could fit 4 pulsars in there Shocked
52Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 5th November 2015, 8:28 pm
Spent last night up there and after turning the lights off realised a cool look Cool
Moley's rebuild - Page 3 IMAG0384_zpstat30cn5
53Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 5th November 2015, 11:21 pm
That's a cool pic!
54Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 5th November 2015, 11:39 pm
Megatron eat your heart out lol ...
55Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 6th November 2015, 5:42 pm
Will do another when she is rebuilt and more shiney Smile
56Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 10th November 2015, 6:24 pm
Had a productive day, got 4wd and front shafts out, oils drained and sump off, brake calipers/carriers and wishbones removed. Cant believe how easy turbo and manifold came off. Gearbox oil came out reather clean considering i havent changed it for around 5 years Embarassed
Found some very small metal swarf in the engine oil drain can so hopefully nothing too serious going on in there. The only thing that puzzled me is a small black fragment sitting in the sump pan when removed; its black and not magnetic so is either black alloy or plastic? Its about 6mm x 3mm, will try and get a good picture at some point.
57Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 10th November 2015, 6:52 pm
@pulsarmoley wrote:Had a productive day, got 4wd and front shafts out, oils drained and sump off, brake calipers/carriers and wishbones removed. Cant believe how easy turbo and manifold came off. Gearbox oil came out reather clean considering i havent changed it for around 5 years  Embarassed
Quite often a small piece brakes off the inside of the oil pump casing. It looks quite tapered and rounded on one end.
58Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 10th November 2015, 7:11 pm
That could be it; there was no oil pressure problems before i took her off the road or would it not affect pump operation?
The best way i could describe it is a 6mm x 6mm square with a 2mm hole in the centre thats snapped in half?
59Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 10th November 2015, 7:17 pm
That doesn't sound like the bit im talking about. The bit im talking about has no roll I think or its a little guide for the timing chain. I cant remember tho.
Its almost like a triangle with a rounded top.
Could do with a pic of the piece ou have found.
60Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 10th November 2015, 7:26 pm
Yeah ill get a good photo, i'd be no good at pictionary/articulate Laughing
61Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 10th November 2015, 7:50 pm
@pulsarmoley wrote:Yeah ill get a good photo, i'd be no good at pictionary/articulate Laughing
Or sherades Laughing
62Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 14th November 2015, 6:38 pm
Ok so getting a photo of the bit never happened as i couldnt find it today but upon further inspection of the oil strainer i started to panic as i could see something else in it. I decided to remove it then refit sump so if sump gets damaged during engine removal it wont damage strainer.
After removing the strainer panic went almost to relief as i know now what the problem was...
Easy to guess what it is...
Moley's rebuild - Page 3 IMAG0387_zpskyai4sag
63Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 14th November 2015, 6:58 pm
Is that a fibre washer or metal?
64Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 14th November 2015, 7:10 pm
at a guess I would say that looks like an injector seal
65Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 14th November 2015, 7:16 pm
Its rubber, i thought it was an easy guess, admittedly its not the best picture. Who going to guess right first??
66Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 14th November 2015, 7:25 pm
Me its rubber off rocker cover washer
67Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 14th November 2015, 7:29 pm
10 points to johnny cheers
So glad its only a rubber washer so hopefully no damage done as it appears it was all caught in the strainer
68Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 14th November 2015, 7:31 pm
@johnny gtir wrote:Me its rubber off rocker cover washer
At first I was thinking injector seal as bob said, but rubber off rocker cover probably makes more sense about how it got in there
69Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 14th November 2015, 7:36 pm
Well theres been a few chances over the years of how it could have got in there, i know there is no way it would of come out during an oil change as it was fairly well wedged in the strainer.
On a side note, am i right in thinking the metal plate around the strainer is a baffle?
70Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 14th November 2015, 7:49 pm
Thats what I would think Smile
71Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 21st November 2015, 9:19 pm
Well i finally got the engine out today, next is the rear subframe, tank etc...
Moley's rebuild - Page 3 IMAG0396_zpsdf3ngzx7
Moley's rebuild - Page 3 IMAG0395_zpstzcjnhmx
72Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 21st November 2015, 9:26 pm
Why did you take the engine out pete ????
73Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 21st November 2015, 9:30 pm
It's good everything came apart easy. Hopefully no other problems.
74Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 21st November 2015, 9:58 pm
@nomad wrote:Why did you take the engine out pete ????
Im gonna rebuild it and make some improvements. It needed to come out as the whole car is being sprayed including engine bay. Im still considering something different for the engine bay...
Yeah woody, piece of cake. All hubs, driveshafts were unbolted and completly removed and pretty much everything out the engine bay except loom as well.
75Moley's rebuild - Page 3 Empty Re: Moley's rebuild on 21st November 2015, 10:11 pm
Go orange in the bay and paint the engine and box black Smile
Or maybe a deap plumb purple Smile
Back to top  Message [Page 3 of 6]
