Gtir Motorsport club » Tech room » Help and Advice » Turbo
Turbo
Go to page : 1, 2, 3  Next
1 Turbo on 7th March 2015, 10:51 am
Gti-r dannyboy
Hi guys in need of some help, how or what can i do to see if there is oil getting to my turbo??
2 Re: Turbo on 7th March 2015, 11:24 am
Whytie
Remove the drain pipe and crank it over with the coil off also pull the fuse for the fuse pump.
3 Re: Turbo on 7th March 2015, 11:27 am
The way I checked was taking the oil feed off the turbo and disconnecting the coil packs and turning the engine over
4 Re: Turbo on 7th March 2015, 12:04 pm
Gti-r dannyboy
Cheers guys done that and there is no oil coming out:( sump is off and found a chuck of metal!!!
5 Re: Turbo on 7th March 2015, 12:17 pm
Where did the chuck of metal come from? What a Face
6 Re: Turbo on 7th March 2015, 12:22 pm
Gti-r dannyboy
Thats what i want to no woody?? I will post a pic, think it mite be of the old turbo
7 Re: Turbo on 7th March 2015, 12:47 pm
Is that the p.r.v. ????
8 Re: Turbo on 7th March 2015, 12:48 pm
I have no idea what that is lol
9 Re: Turbo on 7th March 2015, 1:07 pm
What oil pressure do you have ....
10 Re: Turbo on 7th March 2015, 3:09 pm
Gti-r dannyboy
Whats the p.r.v ??
11 Re: Turbo on 7th March 2015, 3:24 pm
pressure relief valve
12 Re: Turbo on 7th March 2015, 3:28 pm
As mr moley said ...
but don't look like standard one of those.
certainly need GOOD inspection of everything before running that
13 Re: Turbo on 7th March 2015, 3:43 pm
Gti-r dannyboy
What does it exactly do?? I crnt get oil coming thru the pipe that feeds the turbo, i have had the sump off and straightened it bcus it was bent and throught it was blocking the oil feed in the sump
14 Re: Turbo on 7th March 2015, 3:55 pm
If oil pressure goes to high it opens up to release pressure.
basically without it you would have major lack of oil feed.
Some better pics of the item found would be good plus looking for other bits would be good along with inspecting oil pump assembly then take it from there.
15 Re: Turbo on 7th March 2015, 4:04 pm
Gti-r dannyboy
16 Re: Turbo on 7th March 2015, 4:07 pm
Gti-r dannyboy
17 Re: Turbo on 7th March 2015, 4:08 pm
Gti-r dannyboy
18 Re: Turbo on 7th March 2015, 4:11 pm
Gti-r dannyboy
There are no other bits in the sump no metel filings or anything.
19 Re: Turbo on 7th March 2015, 4:21 pm
Well it not oil relief valve ...
Could be something from within the oil pickup strainer seem you got interesting hole in mesh. unbolt it & have a good look.
20 Re: Turbo on 7th March 2015, 4:33 pm
Gti-r dannyboy
With that thing being in the sump and a hole in the mesh it must of past thru at some point , i have the damaged one in my garage i have replace it.
21 Re: Turbo on 7th March 2015, 5:17 pm
Seen a oil pipe clog up remove the metal pipe feeding turbo check its clear. The one i seen was slightly bent and oil was like dry in it
22 Re: Turbo on 7th March 2015, 7:30 pm
Gti-r dannyboy
Oil pipe is removed trying to get the oil out of the block with no joy Sad
23 Re: Turbo on 7th March 2015, 8:00 pm
Anybody know if the rubber o ring is missing from oil strainer if it will stop it sealing and sucking the oil up ?
24 Re: Turbo on 7th March 2015, 8:45 pm
It is but i dont know if the o ring missing would just lower oil pressure or stop it altogether at a guess just lower it
25 Re: Turbo on 7th March 2015, 10:22 pm
If no o-ring or gasket then yes it would effect pump pickup.
Not enough details or pics to know what's going on really.
Where has that part come from because I don't recognise it
For something that been in a nice oily sump it look a bit rusty on the top
Seems you have two strainers compare them & see if you can see any odd differences, bodges
Oil feed to turbo could be purely feed pipe so that best removed & checked for blockage & flow.
I would have a good look at timing cover & pump for any odd signs & also take a look at oil filter too
Exactly why you looking at your turbo oil feed, what led to you assuming oil feed issue !! :-S
