Gtir Motorsport club » General Discusion » Gtir related Discussion » Hand brake
Hand brake
1Hand brake  Empty Hand brake on 9th March 2015, 9:32 am
So what's the deal with my hand brake, doesn't matter how much I tighten the adjustment nut in the cabin the hand brake doesn't feel like it has good bite (even when the height of the handbrake pull is quite short). Half of the adjustment is absolute slop aswell. Not that I've had a real look yet but what are my potential issues? Worn pads, stretched cables, seized calipers?
2Hand brake  Empty Re: Hand brake on 9th March 2015, 9:35 am
How do the rotors look?
If they look as if the pads are working under normal braking then my guess is stretched cables.
3Hand brake  Empty Re: Hand brake on 9th March 2015, 9:54 am
Yeah rotors are fine, not that I've driven the car in a long time but the brakes seemed fine. The hand brake issue existed when I was driving the car regularly anyway.
4Hand brake  Empty Re: Hand brake on 9th March 2015, 10:06 am
Possible issue with adjuster mechanism in the caliper for setting & holding piston/pad gap to disc.
other issue is if the mechanism cam & parts are worn they don't throw the piston as far so you loose a lot of potential clamping load .
All other points you mentioned valid too but if all serviceable then a caliper overhual is way to go & to be honest worth doing anyway unless exceptional condition.
UK guys got this cheap by Big Red recon brake company, think price was about £45GBP a caliper (in useful links section)
If needed i'm sure Oz got similar recon specialist but if stuck or crazy price some UK guys might be able sort & ship perhaps.
5Hand brake  Empty Re: Hand brake on 9th March 2015, 10:42 am
Thanks B, caliper overhaul sounds like the way to go then. Honestly I've never touched them since buying the car so the condition would be unknown. So basically it's a process of elimination if it's not that? I hate brakes Laughing
6Hand brake  Empty Re: Hand brake on 9th March 2015, 11:07 am
Generally it mainly issue with caliper mechanisms as those types of combined hydraulic & mechanical all on same piston are troublesome & more so now nearing 25yrs old.
top condition rotor & decent pads make difference too, cables normally not much bother but certainly want check cables & handbrake lever assembly just to be sure & optimise anything that look less the ideal.
I really hate limp handbrakes & rebuilt mine some time back & difference is huge if rebuild really done well, got slightly larger diameter discs too which helps a tiny bit.
Not that expensive & upgrading front without refreshing rears is not good idea really as faulty piston adjustment on rears causes issues on brakes/pedal feel all round.
7Hand brake  Empty Re: Hand brake on 9th March 2015, 11:20 am
Thanks for the good info mate, looks like this will be getting added to my list of things to do. It might also motivate me to look at upgrading the fronts.
8Hand brake  Empty Re: Hand brake on 16th March 2015, 1:28 am
I had abit of a look today and pads and rotors are fine. When the hand brake is on, one side I can almost turn by hand and the other side I cant.
9Hand brake  Empty Re: Hand brake on 16th March 2015, 7:15 am
^ can you see, both sides lever arm moving correctly via cables !?
If so expect it the adjuster system in one side holding it off disc too far
Can also be cam & linkage worn so does not throw piston far, you should be able see feel piston move if have a helper operate hand-brake while you observing the mechanism & piston movement.
Best route is proper rebuild but you sometimes get away with winding caliper in & pump pedal so it resets itself but if caliper piston & seals look scabby worth proper rebuild really .
10Hand brake  Empty Re: Hand brake on 16th March 2015, 7:35 am
Rebuild both calipers for piece of mind its not a expensive job to do or have done by others. And as said check hand break cables
11Hand brake  Empty Re: Hand brake on 16th March 2015, 8:43 am
I'll get someone to help me check that B, but yeah I'll just get them rebuilt. Thanks guys
12Hand brake  Empty Re: Hand brake on 22nd February 2016, 8:53 am
So I got the caliper's rebuilt, and the discs seem to lock nice and solid now (cant drive the car to test though)
Question: how solid should the hand brake feel? I have the adjustment nuts screwed pretty far in but it does feel kinda spongy. I never had the handbrake working in the R before. In my daily the handbrake kind of feels like its on or off if you know what I mean. The R doesnt feel that way....
13Hand brake  Empty Re: Hand brake on 22nd February 2016, 8:57 am
Sure it should be set between 4 and 6 clicks of the handbreak
14Hand brake  Empty Re: Hand brake on 22nd February 2016, 9:11 am
Ah yeah I haven't checked the number of clicks but at the moment this is where its sitting
Hand brake  Image
Ps I need to new handbrake cover Laughing
15Hand brake  Empty Re: Hand brake on 22nd February 2016, 9:28 am
Way too high, that's like fully extended.
As Bones said, 4-6 clicks, 4 being the optimum.
Mine was on 4, grab lever click, click click (tight), click (securely on). Could pull 5 clicks but it was hard.
16Hand brake  Empty Re: Hand brake on 22nd February 2016, 9:32 am
True, that's with the adjustment nut screwed all the way in with a long socket. Cables fooked then.
17Hand brake  Empty Re: Hand brake on 6th September 2016, 8:17 am
So now we're getting into Autum I'm thinking of all the jobs i need to do over the Winter while my R is in hibernation.
Top of the list is the handbrake. It's really stiff and barely holds, God knows how it got through it's MOT.
So this what I'll do:
1. send rear calipers off to Bigred for refurb,
2. Fit 2x new rear cables,
Is there anything else i could do/replace while I'm at it?
Very Happy Very Happy Very Happy Very Happy
Also, is this cable the correct one to replace item 13 on Nissan4u link
http://www.ebay.co.uk/itm/291775589572?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://nissan4u.com/parts/sunny/el_n14/1992_4/type_50/brake/rear_brake_and_parking_brake_control/illustration_1/
18Hand brake  Empty Re: Hand brake on 6th September 2016, 9:32 am
Picture right but description wrong .
Have a read through, thread below as has all P/N incl BP ones .
Also check out woody's post (No33) as he used a BP front cable and although got it to fit it has slight difference on front thread bar.
If front cable not frayed or rotted you can either adjust pickup bar to reduce length or use a spacer to get more adjustment back .
Most issues link to worn cams & auto adjusters in rear calipers, checking rear cables run free once disconnected both ends, new LH RH cables would be best long term fix over freeing them off if they real stiff.
I think rears would be nissan oem parts as the BP ones seem discontinued or links show wrong part.
Jakoparts did list them but think they only listed one side when I looked into it .
http://www.gtir-motorsport-club.com/t6687-handbrake-cables
19Hand brake  Empty Re: Hand brake on 7th September 2016, 8:31 am
I'm guessing the stretch in the cables must be more common in the rears because they are longer? In my case rebuilding the calipers and replacing the front cable was no difference. Making a spacer is a very easy option.
20Hand brake  Empty Re: Hand brake on 7th September 2016, 8:53 am
Yeh I would go with spacer like you and keep original cables if good order & caliper rebuilt - working as should ...
21Hand brake  Empty Re: Hand brake on 11th May 2017, 9:23 am
I thought they were discontinued but I was able to get the front cable, one side rear cable and the other rear with a 6 week wait from Nissan Japan. So hopefully they come through.
22Hand brake  Empty Re: Hand brake on 11th May 2017, 10:44 am
You can get old cables rebuilt. They just swap out the inner cable.
23Hand brake  Empty Re: Hand brake on 11th May 2017, 11:28 am
Where does that mate?
24Hand brake  Empty Re: Hand brake on 11th May 2017, 12:01 pm
http://www.atscables.com.au/about.html
http://www.cablerepairs.com.au
25Hand brake  Empty Re: Hand brake on 12th May 2017, 2:08 am
Interesting, I've got new ones coming but know for the next time
