Gtir Motorsport club » General Discusion » Random banter » bringing a car out of hibernation
Go to page : 1, 2, 3  Next
1 bringing a car out of hibernation on Fri Mar 27, 2015 10:47 pm
My evo has been sat in the garage for 7 months under a car cover .
My plans are to drain the oil and change the filter for a genuine item.
Then refill and disconnect the coil .
Crank it over till the oil light goes off then reconnect coil and fire it up. .
Is there anything else people could recommend doing .?
2 Re: bringing a car out of hibernation on Fri Mar 27, 2015 11:07 pm
7 months isnt long.
Check all the bushes. I have replaced all the droplinks and bushes on mine.
You might want to take brakes off and copper slip them.
Look for any signs of corrosion on brake lines.
And top up with fresh fuel as the ron drops over time.
3 Re: bringing a car out of hibernation on Fri Mar 27, 2015 11:10 pm
7 months feels like an age buddy ..
4 Re: bringing a car out of hibernation on Fri Mar 27, 2015 11:24 pm
Always does when its something you love that is laid up lol
5 Re: bringing a car out of hibernation on Fri Mar 27, 2015 11:38 pm
Hardy172cup
I know its obvious and probably the first thing you intend to do but put some fresh fuel in it
6 Re: bringing a car out of hibernation on Fri Mar 27, 2015 11:41 pm
I would of said whip the plugs out before turning it over ....
7 Re: bringing a car out of hibernation on Fri Mar 27, 2015 11:57 pm
If your draining the fuel stick a new fuel filter in it aswell. Bet you can't wait to get it back on the road then
8 Re: bringing a car out of hibernation on Sat Mar 28, 2015 7:01 am
@nomad wrote:I would of said whip the plugs out before turning it over ....
Yes rather than just the coil take the plugs out puts no pressure stops things like spinning a bearing
9 Re: bringing a car out of hibernation on Sat Mar 28, 2015 10:17 am
Thermal
Not sure if the Pulsar injects fuel in while cranking, I would not want to inject fuel onto dry bores if it has been standing for some time, I would suggest running up to get it warm before draining the oil, then disconnect the fuel relay, or fuse before cranking for oil pressure. As Johnny says pop out the plugs, this gives you more chance of a quick rise in oil pressure.
10 Re: bringing a car out of hibernation on Sat Mar 28, 2015 10:18 am
Thermal
DOH, EVO not Pulsar, same applies, where are my glasses?
11 Re: bringing a car out of hibernation on Sat Mar 28, 2015 11:07 am
Thermal will you be going to bobs RR day
12 Re: bringing a car out of hibernation on Sat Mar 28, 2015 12:48 pm
Thermal
Rob,The car is in pieces at the mo, I will be trying my best to get it sorted before then, if it is finished maybe a small convoy?
13 Re: bringing a car out of hibernation on Sat Mar 28, 2015 12:51 pm
Where might you be travelling from?
14 Re: bringing a car out of hibernation on Sat Mar 28, 2015 1:03 pm
Thermal
Arundel West Sussex, so probably up the A24, and joining the A23, I have already registered for the new Dart charge just in case.
15 Re: bringing a car out of hibernation on Sat Mar 28, 2015 1:20 pm
We are meeting pulsar23 (not good with names)
In Petersfield . . You could always do more millage and meet us off the boat
16 Re: bringing a car out of hibernation on Sat Mar 28, 2015 1:42 pm
Thermal
I could do the services on the A3, east of Guildford, what day/days are you going up?
17 Re: bringing a car out of hibernation on Sat Mar 28, 2015 2:24 pm
We are going up on the 18th should be up that way for about 10.30
18 Re: bringing a car out of hibernation on Sat Mar 28, 2015 2:51 pm
Thermal
That sounds like a plan, 18th is good for me, I plan to get the car back on the road before then, I will give you a PM nearer the time.
19 Re: bringing a car out of hibernation on Sat Mar 28, 2015 3:36 pm
Sounds like a plan .. so that's a 4 car convoy
20 Re: bringing a car out of hibernation on Sun Mar 29, 2015 11:00 am
Thermal
I suppose I now have to pull out my finger and get on with bolting it back together, windy and rainy at the mo, English summer time begins today!
21 Re: bringing a car out of hibernation on Sun Mar 29, 2015 12:01 pm
Yep finger removed from arsehole please ..
22 Re: bringing a car out of hibernation on Sun Mar 29, 2015 2:57 pm
pulsar23
pulsar23=Danny
23 Re: bringing a car out of hibernation on Sun Mar 29, 2015 4:40 pm
Ah Danny lol
24 Re: bringing a car out of hibernation on Sun Mar 29, 2015 4:45 pm
pulsar23
My brother s maybe coming, 1 in a gto twin turbo and the other 1in his lexus is200 but will confirm
25 Re: bringing a car out of hibernation on Sun Mar 29, 2015 5:15 pm
We could have some fun on the drive over .. varied selection of cars.
