Gtir Motorsport club » Tech room » Help and Advice » Removing ignition barrel
1 Removing ignition barrel on 28th March 2015, 3:32 pm
Hardy172cup
I've found somebody who has a set of door locks and an ignition barrel with a key he is willing to remove from a car he's breaking.
He's come to remove the ignition barrel and realised its not held on with normal bolts, they have a round head?
So my question is how do you remove those bolts?
2 Re: Removing ignition barrel on 28th March 2015, 3:38 pm
Very sharp pointy chisel. .
They are snap bolts for security .. how desperate are ya bill?
3 Re: Removing ignition barrel on 28th March 2015, 3:49 pm
As above. A good sharp chisel at an angle on what's left of the bolt head and it will dig in and start to spin the bolt.
4 Re: Removing ignition barrel on 28th March 2015, 4:39 pm
Gti-r dannyboy
Drill a hole in the middle then tap a flat head screw driver alittle bit bigger than the hole down then unscrew, like i have just done!!!
5 Re: Removing ignition barrel on 28th March 2015, 4:47 pm
Hardy172cup
@Gti-r dannyboy wrote:Drill a hole in the middle then tap a flat head screw driver alittle bit bigger than the hole down then unscrew, like i have just done!!!
Glad you got them off mate and thanks for going through the trouble to remove it for me, I really appreciate it mate thanks.
