Gtir Motorsport club » Tech room » Help and Advice » Transfer box case
Transfer box case
1 Transfer box case on 29th March 2015, 7:31 pm
Ads turbo
Managed to pull case apart while taking gearbox off, can't seem to push case back onto bearing and don't want to damage anything, how do I put it back on ? Thanks
2 Re: Transfer box case on 29th March 2015, 7:43 pm
Spark plug spike
I had the same problem doing mine, took a bit of jiggling around for about 30mins whilst trying to reseat the bearing from the diff casing end seemed to do the trick or I was just lucky!!
Check my thread out it has a picture of the diff end with the bearing/gearing showing I just put a drift in the end and wiggled it about whilst my mate was pushing from the other side?
http://www.gtir-motorsport-club.com/t4617-gearbox-change
3 Re: Transfer box case on 29th March 2015, 7:58 pm
Ads turbo
I did try to push it back on but ended up taking transfer out and removing cover completely so I could clean and seal it, I'll have to have another attempt , thanks
4 Re: Transfer box case on 29th March 2015, 9:03 pm
Ads turbo
[url=http://www.servimg.com/view/19185294/6][img]http://i19.servimg.co
5 Re: Transfer box case on 29th March 2015, 9:53 pm
gtir350
I had the same problem while removing the gearbox , ended up fitting fitting a spare transfer box
6 Re: Transfer box case on 30th March 2015, 6:12 pm
Spark plug spike
Also try rotating the crank pulley at the same time as I did that to refit the diff shaft and also the gearbox and it seemed to make reassembly easier?
7 Re: Transfer box case on 30th March 2015, 6:31 pm
Ads turbo
@Spark plug spike wrote:Also try rotating the crank pulley at the same time as I did that to refit the diff shaft and also the gearbox and it seemed to make reassembly easier?
Will do , thanks
8 Re: Transfer box case on 30th March 2015, 8:21 pm
Spark plug spike
Your link didn't work but I sussed it out
9 Re: Transfer box case on 31st March 2015, 2:09 pm
Ads turbo
@Spark plug spike wrote:Your link didn't work but I sussed it out
Thanks, I'm going to try and get it on after work by using a rubber mallet and tapping around the case.
